Topics [0]
USB Switched Power Takeoff Pointsby jjefferiesinstalling GPS and want to take the power from a switched source | 3 | 770 | Tue 01 Dec 2020, 23:26 by MartinW |
K75 Electrical Gremlinby jjefferiesAnalysis of short in K75 | 8 | 1222 | Mon 30 Nov 2020, 12:55 by 92KK 84WW Olaf |
DIN / Merit Accessory Socket - No Continuityby AUBIEBMW85 K100RS DIN / Merit Accessory Socket Negitive Terminal Has No Continuity To Barrel | 2 | 766 | Mon 30 Nov 2020, 03:09 by Ringfad |
K100LT has no gas gaugeby DanT56 | 6 | 749 | Sun 29 Nov 2020, 05:38 by DanT56 |
Fuel Pump has no power - lostby dallasf | 30 | 1094 | Fri 27 Nov 2020, 23:54 by Suzi Q |
cranking engine[ 1, 2 ] by SoCalK1P1Using battery only, should engine turn over? | 57 | 2551 | Fri 27 Nov 2020, 23:49 by Suzi Q |
K100RS Injector Cleaning and Internal Filter Replacementby AUBIEBMWNew Filter Does Not Look Like Old | 1 | 785 | Thu 26 Nov 2020, 05:38 by charlie99 |
Noob question: Where's the ground on the K75?by roach374 | 9 | 1480 | Wed 25 Nov 2020, 19:56 by roach374 |
Motogadget Button Questionby dwnhillskater | 1 | 888 | Tue 24 Nov 2020, 16:12 by roach374 |
OE Wiring Diagramsby roach374 | 0 | 802 | Tue 24 Nov 2020, 16:10 by roach374 |
BEP Speed Output - Minimal required connections to BEPby PaulM | 4 | 1486 | Mon 23 Nov 2020, 17:46 by Wiz |
Rookie Mistake 2by mritz | 8 | 911 | Sat 21 Nov 2020, 16:14 by robmack |
Rookie Mistake 3 (season finale) - maybe notby mritz | 3 | 693 | Wed 18 Nov 2020, 13:08 by Suzi Q |
rookie mistake...by mritz | 8 | 976 | Tue 17 Nov 2020, 12:23 by Stan |
Speedometer extra lines on speedo whats the go?by daveyson | 14 | 1825 | Thu 12 Nov 2020, 22:37 by ruben |
Sourcing/moulding Odometer gears in Oz - any ideas?by StandardK | 20 | 1658 | Thu 05 Nov 2020, 18:53 by Matthew-Brisbane |
Problems with Acewell 4453 + Bep 3.0 speed and tempby Rampa | 15 | 3037 | Thu 15 Oct 2020, 15:57 by robmack |
Alternator low charge rateby Rockman | 9 | 1152 | Thu 08 Oct 2020, 20:47 by Point-Seven-five |
Starting engine became increasingly weaker, and now bike won't turn overby rclarkbow | 5 | 835 | Wed 23 Sep 2020, 09:03 by 92KK 84WW Olaf |
Ya queda menosby RoadstermacK100 Rs? | 5 | 785 | Mon 21 Sep 2020, 18:23 by brickrider2 |
Flaky Speedo is really starting to annoy meby gorioFlaky Speedo is really starting to annoy me | 9 | 1043 | Fri 18 Sep 2020, 07:57 by gorio |
1989 Ignition Coil?by winmag4582001Replacement | 3 | 913 | Sun 13 Sep 2020, 07:31 by Laitch |
K1100 stopped, wont startby Rockman | 5 | 1085 | Sat 12 Sep 2020, 00:13 by Michael Sydney |
Exit (stage) Left in 100ydsby Terry Dactyl | 8 | 1669 | Fri 11 Sep 2020, 01:43 by Zara |
Coilsby hcritz | 2 | 1939 | Tue 08 Sep 2020, 13:39 by nino |
Cold Idle Bluesby GF Wollongong | 3 | 1000 | Mon 07 Sep 2020, 01:15 by GF Wollongong |
fuel pump fuse keeps blowingby yamaguzzi | 27 | 2492 | Sun 06 Sep 2020, 08:47 by yamaguzzi |
One new coil, coil cover won't bolt upby yankeeone | 4 | 1029 | Mon 31 Aug 2020, 17:23 by yankeeone |
Trouble starting K100by terbet | 12 | 1234 | Mon 24 Aug 2020, 13:20 by terbet |
K100 Speedometer deadby Snod Blatter | 10 | 1428 | Sat 22 Aug 2020, 10:34 by Snod Blatter |
Momentary missby davemadsenTurn signal cause engine to cut out | 8 | 836 | Fri 14 Aug 2020, 20:10 by Laitch |
Spark Plugs[ 1, 2 ] by phil_mars | 59 | 12761 | Tue 11 Aug 2020, 11:10 by Poupy |
Another dud Odometerby StandardK | 5 | 1067 | Sun 09 Aug 2020, 17:26 by StandardK |
Hall sensor - ECU problem ?by ootemotor stopped while riding - no sparking from one coil | 12 | 1525 | Sat 08 Aug 2020, 05:38 by Laitch |
Bike won't turn offby jschara | 3 | 880 | Thu 06 Aug 2020, 15:31 by Dai |
Alternator fixby Phil63 | 12 | 1985 | Thu 06 Aug 2020, 01:23 by Beamer |
K1100LT ABS Issue Electricalby 92KK 84WW OlafK1100LT ABS issue and flat battery | 4 | 1103 | Wed 05 Aug 2020, 12:33 by 92KK 84WW Olaf |
extra wire from one injectorby Rockman | 20 | 1406 | Wed 29 Jul 2020, 18:30 by Rockman |
Starting Issue After New Battery - but maybe before?by bkhK751993 K75 Starter issue | 4 | 753 | Mon 27 Jul 2020, 18:18 by Point-Seven-five |
Faulty speedo finally fixed!by gabriel | 6 | 1037 | Sun 26 Jul 2020, 04:57 by robmack |
Intermittent Crankingby NickyNicky | 10 | 851 | Sun 26 Jul 2020, 00:57 by Arlina |
Temp gage on RSby Danish bikerDo I have the wiring I need? | 12 | 1013 | Tue 21 Jul 2020, 10:05 by Dai |
Starter issues – K100RS[ 1, 2 ] by GeoffP63Starter not engaging to turn motor over | 61 | 6110 | Sun 19 Jul 2020, 20:29 by daveyson |
K100 '84 permanent Neutral Lightby ady954Need advice prior to purchase. | 6 | 935 | Fri 17 Jul 2020, 09:09 by moriarti |
Bargain Quantum fuel pump mounting kits.by MartinW | 5 | 1567 | Wed 15 Jul 2020, 09:53 by brickrider2 |
Ignition live cable ratingby BooG | 6 | 984 | Sat 11 Jul 2020, 23:03 by BooG |
K1100 Motronic & wiring on K100by Vintagemotion | 7 | 1624 | Wed 08 Jul 2020, 05:05 by Vintagemotion |
Starter Relay for 85 K100RSby GeoffP63Which one? | 5 | 1045 | Sat 04 Jul 2020, 21:16 by GeoffP63 |
K1100 RS from 1992 won’t startby Danish bikerTrouble shooting | 15 | 1111 | Sat 04 Jul 2020, 09:02 by Danish biker |
16 v temperature sensor testing values.by MartinW | 14 | 1658 | Tue 30 Jun 2020, 19:39 by Laitch |
Topics [50]
- No new posts
- New posts
- New posts [ Popular ]
- New posts [ Locked ]
