Topics [0]
Electrical tapeby poddyliquid tape | 14 | 960 | Fri Jun 26, 2020 1:30 pm by Suzi Q |
Fuel injector voltage confusionby Tattooist Keith | 36 | 2532 | Mon Jun 22, 2020 5:23 am by Tattooist Keith |
Low Fuel Light Fixby zaubertuba | 3 | 1043 | Sat Jun 20, 2020 11:03 pm by Laitch |
color codesby moriarti | 5 | 1153 | Mon Jun 15, 2020 6:24 pm by moriarti |
Dash switch current ratingby Gaz | 6 | 1139 | Mon Jun 15, 2020 8:38 am by Dai |
Rebuilding a K Odometer using inexpensive eB*y gears- a (rough) guideby StandardK | 10 | 1688 | Sat Jun 13, 2020 7:40 pm by StandardK |
What does this do?by Stumpy | 12 | 949 | Fri Jun 12, 2020 4:04 pm by Stumpy |
Motronic or fuel pressure defect?by geoff barnettEngine ignition and very brief combustion - and then just as quickly expires... | 2 | 905 | Wed Jun 10, 2020 9:18 am by 92KK 84WW Olaf |
Electric screenby Dai | 2 | 883 | Sun Jun 07, 2020 5:54 pm by Dai |
Charge leakageby tinyspuds | 11 | 1014 | Fri Jun 05, 2020 8:35 am by tinyspuds |
Headlight upgrade experiences[ 1, 2 ] by Comberjohn | 96 | 11224 | Tue Jun 02, 2020 3:37 pm by Point-Seven-five |
Odometer on 1985 K100by BadjerJim | 15 | 6857 | Mon Jun 01, 2020 5:52 pm by Beamer |
speedo only works when in gearby mister_anger | 0 | 754 | Fri May 29, 2020 3:39 am by mister_anger |
K100LT radio remoteby DiverPeteLooking to find out how it originally functioned | 9 | 1521 | Thu May 28, 2020 7:15 am by dakelvinator |
K100RS 1984 not starting easilyby gerryteThe bike has around 40k km and has run reliably since new. Following some very hot rides, fuel pump stopped running and then fan ould not come in. | 15 | 1314 | Wed May 27, 2020 5:32 am by Stumpy |
Need help with these wiresby ChewbackerWhere do these go pls? | 7 | 1129 | Thu May 07, 2020 4:04 am by harrowbmw |
Which Headlamp Bulb?by Bonzo | 6 | 883 | Tue May 05, 2020 7:00 pm by volador |
Circuit diagram or parts list of instrument cluster.by jayk47 | 3 | 1681 | Sun May 03, 2020 11:56 pm by Cablebeacher |
plugs sockets under tank, where do they go.by toddyBMW | 6 | 950 | Sun May 03, 2020 1:06 am by toddyBMW |
K100 Sparks in the tank !by toddyBMW | 4 | 1070 | Sun May 03, 2020 12:22 am by MartinW |
Gear indicator bench testby CablebeacherTest gear indicator OFF bike | 3 | 883 | Thu Apr 30, 2020 4:33 am by MartinW |
Plug Identificationby RockymountainmotoHelp me identify this plug | 13 | 1954 | Tue Apr 28, 2020 12:56 pm by Rockymountainmoto |
DRL & headlight colours mismatch UKby tinyspuds | 33 | 1137 | Tue Apr 28, 2020 5:30 am by tinyspuds |
Cheap repair for fuel sender - Am I an idiot?by mynameisrodney | 9 | 1315 | Mon Apr 27, 2020 9:20 pm by mynameisrodney |
Charge lamp issueby pulhamdown | 4 | 929 | Thu Apr 23, 2020 5:34 pm by Dai |
Stuck speedo and rev counterby JGT | 5 | 999 | Wed Apr 22, 2020 1:53 pm by 92KK 84WW Olaf |
[solved]Flasher Module Problemby Point-Seven-five | 18 | 1571 | Mon Apr 20, 2020 6:19 pm by volador |
Anti-Theft System 85 K100-RTby geharperDisable Anti-Theft | 1 | 796 | Mon Apr 20, 2020 3:05 pm by Point-Seven-five |
Horn stuck on??by giltgy | 9 | 1157 | Mon Apr 20, 2020 10:14 am by geharper |
Alternator connectionby freed | 3 | 1259 | Sun Apr 19, 2020 5:29 pm by Two Wheels Better |
Trouble with temp sensorby Gauntlett | 4 | 883 | Thu Apr 16, 2020 2:36 pm by Gauntlett |
Help identify this connector on K100 16V pleaseby stanthomas | 15 | 1076 | Sun Apr 12, 2020 11:07 pm by Two Wheels Better |
grey vs black vs black & red ignition coilsby tinyspuds | 2 | 1014 | Thu Apr 09, 2020 9:39 pm by tinyspuds |
Instrument Pod Assembly ?? Today's Corona Project.by MartinW | 14 | 929 | Mon Mar 30, 2020 5:12 pm by MartinW |
A quick ABS Warning Relay question.by Bonzo | 5 | 858 | Mon Mar 30, 2020 4:24 pm by Point-Seven-five |
China speedometer Rotational Speed wrongby cafe_racer_freak | 1 | 882 | Tue Mar 24, 2020 12:51 pm by Laitch |
Fuel Injection Relayby MartinW | 10 | 1398 | Tue Mar 24, 2020 4:02 am by Stumpy |
Clock and Gear LCD'sby Cablebeacher | 7 | 1155 | Wed Mar 11, 2020 10:33 am by Laitch |
Choke control positionsby Cablebeacher | 6 | 1024 | Tue Mar 10, 2020 8:26 pm by MartinW |
Bike cut out and then the fan came on a few times today :-(by Bonzo | 17 | 1019 | Mon Mar 09, 2020 5:09 am by Bonzo |
DeoxIT question (sorry)by Bonzo | 9 | 938 | Sun Mar 08, 2020 5:33 pm by Snod Blatter |
fan motors reacting differently to temp sensorby 88 | 4 | 977 | Mon Mar 02, 2020 9:59 am by 88 |
Is there a side stand cutout bypass switch for 16v?by Bonzo | 6 | 1167 | Sun Mar 01, 2020 12:35 pm by Point-Seven-five |
sticky turn signal cancel buttonby tonybob | 6 | 989 | Tue Feb 25, 2020 1:22 am by Point-Seven-five |
1985 K100RS Charging Problemby Bfgben | 18 | 3096 | Thu Feb 13, 2020 6:55 am by Dai |
RIP MotoBattby Dai | 10 | 1539 | Sat Feb 08, 2020 8:10 pm by redrockmania |
Extra Speaker output`s on a (BMW Radio CLARION PU9203A in a K1100lt 1992)by dakelvinatorHow to? amp? Extra Speaker output`s on a (BMW Radio CLARION PU9203A in a K1100lt 1992) | 8 | 1445 | Tue Feb 04, 2020 2:55 pm by dakelvinator |
Air Leak Issue - Rubbersby GF WollongongIdles improves when hot | 3 | 939 | Sun Feb 02, 2020 7:48 am by duck |
So that was the noise!by GF WollongongFirst ride after 8 years off the road ... R65 | 2 | 926 | Sun Feb 02, 2020 5:27 am by Dai |
Fuel Injectorsby Retro RebuildsWon't Start | 6 | 1296 | Sun Feb 02, 2020 2:32 am by GF Wollongong |
Topics [50]
- No new posts
- New posts
- New posts [ Popular ]
- New posts [ Locked ]
