1Back to top Go down   My side panel repair Empty My side panel repair Thu Jul 12, 2012 10:14 am
Brickee
Brickee
I thought I would post my side panel repair from seeing 88K's repair in another post.
First, I took what was left of the hook and glued it back using super glue.
My side panel repair Side_p19
Next I found an old plastic license plate frame (it's about 1/8" thick) and cut out a piece to size.
My side panel repair Sd_3_110
I then scribed the outline of the hook onto the plastic and then cut it out with a coping saw giving me this.
My side panel repair Side_p20My side panel repair Sd_312
Then I clamped it in place and glued it. I originally used super glue, but it didn't hold up, so I reglued it using JB Weld.
My side panel repair Sd_611
I then filed it down to match the contour of the hook, and so far, so good
I hope this is of help to someone, and I realize there's a lot of room for improvement.
Just thought I'd try to give back a little for all the help you lot have given me. My side panel repair 112350
86 K100RT VIN 0053533
The good news is, I no longer have senior moments. The bad news is, now it's a constant state of mind.
2Back to top Go down   My side panel repair Empty Re: My side panel repair Sat Jul 14, 2012 7:34 am
That's good sound lateral thinking, well done, will keep it in mind for mine
3Back to top Go down   My side panel repair Empty Re: My side panel repair Mon Jul 16, 2012 8:14 pm
Nice repair Brickee. Lucky you had the broken off bit for a template. Mine was long gone unfortunately. Very resourceful My side panel repair 112350
My side panel repair Ir-log1188....May contain nuts!My side panel repair Ir-log11
K75RTP - 1994
4Back to top Go down   My side panel repair Empty Re: My side panel repair Mon Jul 16, 2012 8:47 pm
Brickee
Brickee
Why not use the other side panel as a template, it's just the opposite hand. Failing that, I'm sure one of the lads near you could let you use on of theirs for a template. You just might need to use heavier stock to make up for the missing hook.
5Back to top Go down   My side panel repair Empty Side panel repair update Mon Apr 22, 2013 8:37 pm
Brickee
Brickee
If at first you don't succeed----
That repair lasted 1 season. I had replaced the tank grommets with new ones the winter before and they made the side panel really tight. I was afraid the top button would break off before it came out, but it just broke the repair. I had a feeling it wasn't beefy enough, but thought I was on the right track. So back to the drawing board.
This time I used 1" x 1/8" aluminum stock and cut it to size and used a coping saw to get the proper shape.
My side panel repair Sc_upd10
and bolted it for good measure
My side panel repair Sc_upd11
A shot of it in place on the bottom arm.
My side panel repair Sc_upd12
Not especially pretty, but I'm hoping a lot more functional and longer lasting!
