Topics [0]
K100LT gearingby JGT | 6 | 1439 | Mon May 07, 2012 11:18 pm by 92KK 84WW Olaf |
repairing an outputshaft ???by dewalque | 18 | 2022 | Mon May 07, 2012 4:32 pm by dewalque |
Modifying the cam timingby Finally_A_KAnybody here ever try this? | 28 | 3673 | Mon May 07, 2012 11:17 am by ReneZ |
Fitting of shaft seal in timing chain coverby ReneZNew type seal (PTFE) - fit dry or wet?? | 9 | 3352 | Mon May 07, 2012 6:08 am by Two Wheels Better |
Change in start up since TB workby MT350Explorer | 3 | 1428 | Sat May 05, 2012 11:33 am by ReneZ |
Now I've done it...[ 1, 2 ] by club_c | 69 | 3952 | Fri May 04, 2012 10:57 am by 88 |
Oil seeping from belowby MT350Explorer | 16 | 1740 | Tue May 01, 2012 8:28 pm by MT350Explorer |
cooling systemby lessoraidiator | 13 | 2370 | Sun Apr 29, 2012 12:59 pm by beanoldboy |
Oil on the Garage floorby caferacer62 | 32 | 2078 | Sun Apr 29, 2012 11:20 am by Two Wheels Better |
Nightmare leak near the brick? Hope this isn't an overhaul.by TSBT | 14 | 6288 | Fri Apr 27, 2012 2:38 am by TSBT |
Stuck Oil drain plugby AgerbundsenK100RS 4Valve | 15 | 3167 | Tue Apr 24, 2012 3:07 pm by Agerbundsen |
Help - changed TB rubbers and now the throttle is stuckby MT350Explorer | 16 | 1696 | Sat Apr 21, 2012 10:01 pm by MT350Explorer |
engine sputters on throttleby kringb | 35 | 8017 | Fri Apr 20, 2012 8:39 pm by ReneZ |
Cleaning up the K75Sby C_Mick | 8 | 2143 | Fri Apr 20, 2012 1:52 am by C_Mick |
Spline Lube & Leaking Sealby Two Wheels Better | 24 | 3157 | Thu Apr 19, 2012 3:51 pm by 88 |
Engine Cleaning...by twincarb | 7 | 2045 | Sun Apr 15, 2012 7:37 am by Halo |
Cylinder Head removalby 88 | 8 | 2477 | Sat Apr 14, 2012 6:26 am by walfish |
cleaning up the engine caseby artie86 | 2 | 1970 | Fri Apr 13, 2012 10:29 pm by artie86 |
Exhaust Leak uncoveredby RT | 7 | 2694 | Fri Apr 13, 2012 9:28 pm by Crazy Frog |
oil sumpby lessobolts | 3 | 2325 | Fri Apr 13, 2012 8:54 pm by K-BIKE |
Weird Startingby Hover K100Starts without airflow meter | 15 | 1666 | Thu Apr 12, 2012 6:58 pm by Inge K. |
oil sumpby lessosilicone | 6 | 1799 | Wed Apr 11, 2012 5:41 pm by lesso |
k100 oil sumpby lessok100rt 1987 | 3 | 1525 | Wed Apr 11, 2012 11:20 am by lesso |
Using 90W L.S Gear Oilby giles4060 | 5 | 1650 | Sun Apr 08, 2012 8:40 am by giles4060 |
Alternator oil sealby voggsson | 2 | 2392 | Sat Apr 07, 2012 4:45 pm by voggsson |
K75 clutchby canazei1200clutch problem | 9 | 2381 | Sat Apr 07, 2012 11:41 am by whhoon |
new K100 Dies .. HELP!!!by jeffhestand | 3 | 1678 | Fri Apr 06, 2012 6:17 am by K-BIKE |
Timing Chain Tensioner problem of a different kind.by MLR | 21 | 3669 | Fri Apr 06, 2012 1:38 am by Inge K. |
oil filter removelby lessoarrrrrr | 6 | 1475 | Thu Apr 05, 2012 1:09 pm by blaKey |
Dredded Spragg troubles...........by andybDredded Spragg troubles........... | 4 | 1469 | Thu Apr 05, 2012 3:26 am by Rick G |
I think the temp gauge is faulty 92 100rsby krome | 7 | 1410 | Thu Apr 05, 2012 1:19 am by Inge K. |
Loctite typeby HaloWhat type of loctite do I use to stop the final drive outer racer from spinning on the case ? | 3 | 1403 | Wed Apr 04, 2012 11:17 am by Dennis |
FUEL HOSE SUPPLYby CanberraDave | 2 | 1495 | Wed Apr 04, 2012 4:02 am by K75cster |
ready for 2012 season ? what probs have youby zonenfeile | 11 | 1853 | Tue Apr 03, 2012 10:06 am by MT350Explorer |
Crankcase breather hoseby RT | 11 | 5666 | Mon Apr 02, 2012 1:18 pm by RT |
TDC TOOL???????by PucciniHow do you use them | 20 | 3073 | Sun Apr 01, 2012 6:39 am by K75cster |
Vapour on headstock/frame on steering lock side when running/Will a k1100 radiator fit?by artie86 | 4 | 1477 | Sun Apr 01, 2012 1:09 am by artie86 |
1985 K100RS throttle position switchby brickriderAdjustment | 5 | 1833 | Wed Mar 28, 2012 6:07 pm by brickrider |
How to remove the alternator dog drive?by ricketyclik | 3 | 1653 | Wed Mar 28, 2012 2:24 pm by yankeeone |
IGNITION LEADSby RSMITH | 4 | 1386 | Wed Mar 28, 2012 11:03 am by RSMITH |
"choke" lever wont stay in positionby RSMITH | 9 | 2271 | Wed Mar 28, 2012 7:34 am by Rick G |
If it ain´t broken.....by bjarnek100 | 2 | 1191 | Tue Mar 27, 2012 11:23 pm by Moto Smith |
Mystery buzzzzzby Dennis | 28 | 2496 | Mon Mar 26, 2012 1:50 pm by nino |
exhaust changeby arbalestchange muffler on K100 for tire clearance on high performance sidcar | 8 | 2018 | Sat Mar 24, 2012 4:15 pm by arbalest |
Stalling after idleby Scorn | 5 | 1518 | Thu Mar 22, 2012 4:52 pm by Moto Smith |
Fuel smellby nick | 12 | 2241 | Thu Mar 22, 2012 12:49 am by andyb |
TB adjustment questionby Puccini | 13 | 1830 | Wed Mar 21, 2012 10:14 pm by brickrider |
engine temperatureby abbocath | 29 | 3679 | Tue Mar 20, 2012 9:11 am by col |
Leaky intakeby James | 2 | 1459 | Sun Mar 18, 2012 10:38 pm by James |
a couple of problems in new season...by pajonk | 5 | 1328 | Sat Mar 17, 2012 7:54 am by K-BIKE |
Topics [50]
- No new posts
- New posts
- New posts [ Popular ]
- New posts [ Locked ]
