1Back to top Go down   K100RS Mirror/indicator Empty K100RS Mirror/indicator Sat Jun 15, 2013 8:09 am
Has anyone stripped the K100RS mirror/indicator assembly down to its smallest components?....I could pull it apart but I imagine the broken bits would explain how I should have done it....trying to avoid that they are too pricey to replace.
I want to get this bit out...
K100RS Mirror/indicator Indica10
KKlompy K100RS Mirror/indicator 2854237993
K100RS Mirror/indicator Au-log10
2Back to top Go down   K100RS Mirror/indicator Empty Re: K100RS Mirror/indicator Sat Jun 15, 2013 8:19 am
That piccy is of the tail indicator, the mounting screw is on the rear side of the housing.
At the front indicator a single mounting screw is at inner end of the lens.
Pull the lens out in the same direction as the screw, (it's a small hook at the outer
end of the lens).....the gasket could be a bit sticky, a small amount of force could be needed.
3Back to top Go down   K100RS Mirror/indicator Empty Re: K100RS Mirror/indicator Sat Jun 15, 2013 8:58 am
Thanks mate I could not find a picture in Motorworks or Motobins....so here is an I phone contribution....this is as far as I can pull it down at the moment...
K100RS Mirror/indicator Img_0318
K100RS Mirror/indicator Img_0319
K100RS Mirror/indicator Img_0320
4Back to top Go down   K100RS Mirror/indicator Empty Re: K100RS Mirror/indicator Sat Jun 15, 2013 10:26 am
That is as far as I can get into mine too. I am just about to take them apart again to fit the LED light panels for the indicators.
5Back to top Go down   K100RS Mirror/indicator Empty Re: K100RS Mirror/indicator Sat Jun 15, 2013 12:11 pm
I kind of assumed they were clipped together as you cannot get to the workings unless the plastics are separated...and of course no screws or rivets....mmmmmmm
6Back to top Go down   K100RS Mirror/indicator Empty Re: K100RS Mirror/indicator Sun Jun 16, 2013 4:56 pm
Klompy, the two halves are glued together and don't come apart easily.
7Back to top Go down   K100RS Mirror/indicator Empty Re: K100RS Mirror/indicator Sun Jun 16, 2013 11:01 pm
now why did they do that....a couple of screws would have sufficed...may have to retrofit some fasteners after I have pried a donor mirror indicator assembly apart....will take pictures as I destroy one for a good cause...
8Back to top Go down   K100RS Mirror/indicator Empty Re: K100RS Mirror/indicator Sun Jun 16, 2013 11:07 pm
The only time they come apart is when you are showing someone how they are glued together so well they dont come apart.
I have had some success with the RT/LT type by giving them a twist and that sometimes breaks the glue away then clean them up and use a stanley knife to scrape it down to the black plastic where it glues together and use super glue to stick them back together. 2 or 3 places with a small dab and when you decide you want it to stay run some into the groove and it's done.
Bikes 2004 K1200GT (crashed I lived it died) 1999 K1100 LT.
9Back to top Go down   K100RS Mirror/indicator Empty when I painted Sun Jun 16, 2013 11:43 pm
ibjman
ibjman
When I painted my 85rs I just gently pried around the edges all around....sooner or later you find a couple of weak spots and the 2 halves start to separate. The further around you get, the easier it gets to break the glue joints. Both of mine came apart relatively easy as no one had glued them up in a previous repair, I guess.
After the paintwork I just glued them back together with Testors model airplane (Styrene) cement & put a rubber band around them for a few hours till set.
 They seem to be holding together fine.....I have not intentionally "stressed" them to test the glue joints
10Back to top Go down   K100RS Mirror/indicator Empty First a rant, then an offering Thu Aug 27, 2015 9:37 pm
nolo
nolo
I just replaced the right mirror assembly on my 1996 K1100RS.  I have to say I have been disappointed at several stages during the process.  The mirror was completely missing when I bought the bike.  The previous owner said it was damaged when he dropped it in his garage.  I purchased an OEM "Mirror Assembly" online for just North of $200.  When I received it, I was dismayed to find that a "Mirror Assembly" does not include the mirror glass.  I called the dealer, and after some checking, I was told that indeed the mirror glass does not come with the "Assembly".  Personally, I would have called it a housing instead of a mirror assembly.  Anyway, I ordered the glass and decided to paint the housing while I waited.  It came out beautifully, if I do say so myself.  I received the mirror glass, waited a couple of days for the paint to dry then started re-assembly today.  No instructions came with the housing or the mirror glass.  The glass did come with a spring clip, but no pictures or directions explaining how to use it.  I couldn't see how to access the back of the glass to install the pin.  So I hit the net.  The only video I could find was for a K100 but the guy briefly mentioned the pin for the 1100RS units.  I found this thread.  I thought "Awesome!"  I had found the information I needed.  Someone said something about separating the two halves of the housing.  Tried that, didn't work.  Someone else said, "Yeah, it's glued.  You really have to pry hard."  Did that.  Got it apart.  Screwed up my beautiful paint job.
Then I discovered (this is the juicy part) the new housings come with a spring clip pre-installed.  All I needed to do was press the mirror glass in until the clip snapped in.  No disassembly required.
Sometime this winter, when I'm not riding, I'll repaint the housing.  But for now, all I can hope is that my story saves someone else the grief I experienced because BMW doesn't include simple installation instruction or drawings (no translation required) with their replacement parts.  By the way, I own a repair manual for this bike.  It does not cover mirror replacement.
Ride safe,
Nolo
11Back to top Go down   K100RS Mirror/indicator Empty Re: K100RS Mirror/indicator Thu Aug 27, 2015 10:00 pm
The RS mirrors have a habit of committing suicide at the most inconvenient moment like when a truck is following so many here have made security lanyards from fishing trace that prevents it going too far when they come detached.
12Back to top Go down   K100RS Mirror/indicator Empty Re: K100RS Mirror/indicator Thu Aug 27, 2015 10:04 pm
nolo
nolo
Absolutely!  A quick trip to the sporting goods section of Walmart got me a six pack of 12" steel leaders.  That was an awesome tip I got from this site, and have already installed on the new mirror.
Thanks,
Nolo
13Back to top Go down   K100RS Mirror/indicator Empty Re: K100RS Mirror/indicator Sat Aug 29, 2015 11:24 am
Snowy Mountains Mick
RicK G wrote:The RS mirrors have a habit of committing suicide at the most inconvenient moment like when a truck is following so many here have made security lanyards from fishing trace that prevents it going too far when they come detached.
Now ya thinking!
14Back to top Go down   K100RS Mirror/indicator Empty Re: K100RS Mirror/indicator Mon Nov 30, 2015 1:46 pm
piseth
piseth
Any possible to stick the mirror sets to the mounting so it doaent comes out? someone knock into my left side mirror and its a pain in my butts cause it drops out half way when i was ridding and broke the clips on it. So got back to shop and got a replacement. So im afraid that i have to keep on buying more mirrors
Laughing Laughing Laughing
K100 RS 1990 December
Last Location: Japan
Current Location: Cambodia
vin:0201460
