Topics [0]
New battery, no power.by wheels149 | 17 | 1993 | Tue May 12, 2015 6:10 am by wheels149 |
Frustrated 1985 K100RS Ownerby robdiaz44Problem after problem | 30 | 5619 | Mon May 11, 2015 9:47 pm by robdiaz44 |
A number of questions seeking a number of answers[ 1, 2, 3 ] by Hessian | 130 | 6720 | Fri May 08, 2015 7:50 am by Hessian |
Need practical advice for ABS code reader and trouble shootby 3DdesignsK75S | 9 | 1535 | Fri May 08, 2015 5:04 am by Rick G |
Whats the throttle position switch for?by Puccini | 10 | 2743 | Wed May 06, 2015 7:33 am by Puccini |
Motometer Parts Explosion Diagrams for OEM Instrument Clusterby robmack | 4 | 2462 | Tue May 05, 2015 1:07 am by rawdonball |
K1100 - Tickover slows then dies, intermittent misfire, poor starting, loss of power, engine cuts in turns.by GerryP | 3 | 1677 | Sun May 03, 2015 12:42 pm by GerryP |
Battery Dischargeby ShedBob | 18 | 2125 | Sun May 03, 2015 6:48 am by GerryP |
K100/K1100 Handlebar Switchgear etc.by kramboDirect swap ? | 9 | 1826 | Fri May 01, 2015 6:28 pm by krambo |
Gremlinsby Point-Seven-fiveIntermittant problems | 33 | 2081 | Thu Apr 30, 2015 10:24 pm by Point-Seven-five |
Tachometer Chaosby Motorbike Mike | 2 | 1741 | Sun Apr 26, 2015 11:27 pm by KafeRacer |
Can I Cut These Wires Off....by bettyswolloks | 5 | 1690 | Sat Apr 25, 2015 5:09 am by bettyswolloks |
87 k100 RT, intermittent fuel pump operation. SOLVED!by fourwinds | 5 | 1767 | Sat Apr 25, 2015 1:28 am by fourwinds |
Ignition Leadsby Big GIgnition Leads | 2 | 1314 | Fri Apr 24, 2015 7:45 am by Dai |
K1100 shocker on K100by Packo | 1 | 1325 | Tue Apr 21, 2015 9:54 pm by Rick G |
2cyl K100[ 1, 2 ] by KlausmeisterPerplexing problem | 57 | 3300 | Mon Apr 20, 2015 9:54 am by 92KK 84WW Olaf |
K100 sick overnightby KlausmeisterRan perfectly and next day, starts with lots of throttle but dies after a couple of seconds. | 3 | 1287 | Mon Apr 20, 2015 4:20 am by charlie99 |
speedo testingby Rockman | 3 | 1367 | Mon Apr 20, 2015 3:45 am by Rick G |
has anyone made a custom wiring harness?by desperado | 6 | 5708 | Tue Apr 14, 2015 7:39 pm by robmack |
Dropping cylinders intermittently when warm. Probably coils?by Rustybottom | 7 | 1616 | Mon Apr 13, 2015 2:01 pm by brickrider |
Taller Battery Hold Down Questionby kringb | 9 | 1730 | Mon Apr 13, 2015 1:13 pm by kringb |
Temperature Relayby Oliveri | 13 | 1879 | Fri Apr 10, 2015 5:02 am by Oliveri |
Have I screwed the starter relay?by Noeloakesstarter relay shorted | 2 | 1333 | Tue Apr 07, 2015 8:43 am by Rick G |
Aftermarket Oxford grips wiring.by touchwoodsdenAftermarket Oxford grips wiring. | 9 | 1521 | Fri Apr 03, 2015 6:04 am by WoodyAUK75 |
LED Tail light Helpby jhouse07cant figure it out | 13 | 1922 | Fri Apr 03, 2015 2:48 am by charlie99 |
Still trouble with speedometer after much workby jhouse07need help with speedo again | 16 | 1928 | Tue Mar 31, 2015 6:23 pm by jhouse07 |
Adding the Fuel level gauge and water temp gauge back...by MikeisonTV | 2 | 1515 | Tue Mar 31, 2015 2:38 pm by MikeisonTV |
an answer that needs the proper question. sorry Hessianby CommanderKewl | 3 | 1136 | Sun Mar 29, 2015 10:16 pm by 92KK 84WW Olaf |
K1100 no power at starterby Packo | 18 | 2933 | Sun Mar 29, 2015 5:39 am by charlie99 |
DIN Numbersby Dai | 2 | 1344 | Sun Mar 29, 2015 1:25 am by Holister |
temporary fix headlightsby wsiddinsfaulty switches | 7 | 1421 | Sun Mar 22, 2015 4:38 am by Holister |
Starter motor not turning over[ 1, 2 ] by Oliveri | 50 | 5161 | Sat Mar 21, 2015 5:43 am by charlie99 |
Right hand light switch starter button shorting outby wsiddinsBike will start when in gear from RH light switch | 1 | 1291 | Wed Mar 18, 2015 9:03 pm by Rick G |
Headlight woesby kramboInitially lost main beam, now have lost low beam also. | 6 | 1366 | Fri Mar 13, 2015 9:11 pm by krambo |
Air flow meter issuesby xatzigiorgis | 16 | 2039 | Wed Mar 11, 2015 6:20 am by xatzigiorgis |
Temperature Relay - Cooling fan not workingby floyd | 19 | 2147 | Mon Mar 09, 2015 6:19 pm by floyd |
switch on lights instruments dieby mawhera | 1 | 1233 | Tue Mar 03, 2015 6:38 pm by Inge K. |
Bulb Monitoring Unit doesn't like LED in the instrument clusterby elukrosWarning light in instrument cluster briefly lights up when brakes are applied | 15 | 3299 | Tue Mar 03, 2015 3:11 pm by Dai |
What's the blue relay for???by ffbikersaTrying to deciphre the relay box | 4 | 2123 | Sat Feb 28, 2015 1:21 pm by ffbikersa |
Odometer gears for my K100RSby td5 | 7 | 2055 | Wed Feb 25, 2015 1:12 pm by Born Again Eccentric |
Coolant Temp Gaugeby floyd | 5 | 3195 | Tue Feb 24, 2015 3:08 am by charlie99 |
K1100LT cooling fan electrics queryby DeRodster | 5 | 1435 | Sun Feb 22, 2015 8:41 pm by Arlina |
Load shed and EFIby SteveK11990 K1 | 22 | 2731 | Fri Feb 20, 2015 8:34 pm by Rick G |
Another K100 Joins the Shed.by Tom G | 7 | 1634 | Sat Feb 14, 2015 8:57 pm by Tom G |
Starting issue....[ 1, 2 ] by BooG | 86 | 4391 | Sat Feb 14, 2015 5:32 pm by BooG |
Gear position switch.by sidecar paul | 16 | 12193 | Thu Feb 12, 2015 8:41 pm by Point-Seven-five |
Replacing the Cooling Fanby KClassAny suggestions | 22 | 6371 | Thu Feb 12, 2015 3:01 pm by Kyle10 |
Am i a plonker or is my battery duff?!by ssj_Gill | 8 | 1505 | Mon Feb 09, 2015 11:50 pm by Holister |
Alternator Brushesby cliverocky | 2 | 1207 | Fri Jan 30, 2015 3:29 am by charlie99 |
headlightby smoll1 | 19 | 1879 | Sun Jan 25, 2015 8:50 pm by Arlina |
Topics [50]
- No new posts
- New posts
- New posts [ Popular ]
- New posts [ Locked ]
