Topics [0]
Apparent shifting failure -- anything I should look for?by FreyZItroubleshooting transmission | 5 | 1260 | Tue Nov 29, 2016 7:57 am by Dai |
I had those sprag clutch bluesby BIG D | 5 | 1422 | Sat Nov 26, 2016 3:44 pm by Jeffmedic |
Bleeder control chain housing?by Chocolate | 5 | 1367 | Fri Nov 25, 2016 6:16 pm by Motorbike Mike |
Oil Pressure , Need Helpby Warhammeroil in sight glass takes forever to drop | 43 | 3184 | Thu Nov 17, 2016 6:49 am by Rick G |
Water pump shaft and seal issues. Incompatibilities???by Atsea | 4 | 1697 | Tue Nov 15, 2016 12:22 pm by Atsea |
Crank Case Breather Pipes - Airbox Removalby CalvertLooking for some suggestions | 8 | 2106 | Tue Nov 15, 2016 5:08 am by Rick G |
Overheatingby mybillyboy52Overheating advice. | 39 | 3052 | Fri Nov 11, 2016 11:58 am by Kando |
1990 K100LT intermediate "whacking sound" while running.by Banzaibob | 18 | 1620 | Sat Nov 05, 2016 6:36 pm by Holister |
k100 drive onto k75by Beamer | 9 | 2397 | Sat Nov 05, 2016 5:01 pm by Beamer |
Smoothing the handlebar buzzby audibob | 2 | 1360 | Sat Nov 05, 2016 6:12 am by audibob |
K1100LT with no compression on cylinder 3 - most likely cause ?by krambo | 19 | 2898 | Sat Oct 22, 2016 11:18 am by Bumblebee |
16V cam chain tension release toolby KiwiK100 | 5 | 1303 | Fri Oct 21, 2016 9:58 am by Holister |
Engine noise on cold (again)by nino | 6 | 1489 | Thu Oct 20, 2016 2:23 am by nino |
Oil leak. Help.by shipo282 | 20 | 2943 | Tue Oct 18, 2016 1:59 am by k-rider |
Newbie not starting questionby corran57Bike not starting | 15 | 1591 | Thu Oct 13, 2016 11:24 pm by corran57 |
Timing chain markby nino | 6 | 2291 | Wed Oct 12, 2016 2:32 am by SniperX |
Engine running rough after over filling Tank with Gas[ 1, 2 ] by veetsEngine will not idle and running rough | 82 | 4266 | Mon Oct 10, 2016 8:26 pm by 92KK 84WW Olaf |
Replacing fuel delivery and return hoses on 1984 K100RSby LeonWAdvice needed to change fuel hoses | 12 | 3766 | Mon Oct 10, 2016 4:39 am by 92KK 84WW Olaf |
timing case removalby SniperX | 20 | 3507 | Mon Oct 10, 2016 2:05 am by SniperX |
A question for K1200RS owners.by Comberjohn | 4 | 1483 | Fri Oct 07, 2016 2:45 pm by Two Wheels Better |
Spark plug cover questionby KiwiK100 | 2 | 1516 | Sun Oct 02, 2016 7:13 am by duck |
TB Balanceby KafflutThose butterfly adjustment screws ... | 2 | 1270 | Wed Sep 28, 2016 1:59 am by Kafflut |
Fuel dump after motor non startby audibob | 6 | 1408 | Sat Sep 24, 2016 1:33 pm by audibob |
Valve, Seat & Guide Material - K100by dac104y | 2 | 1351 | Sun Sep 18, 2016 6:50 am by dac104y |
Coolant overflow tank move/removalby rxbbie | 14 | 6077 | Thu Sep 15, 2016 3:11 am by Gaz |
Balanced TBs ?by KafflutTB vacuum take-offs connected | 1 | 1289 | Wed Sep 14, 2016 2:09 pm by k-rider |
Throttle body #4 won't balanceby Roland5Throttle body #4 won't balance - turn the adjustment screw and nothing changes | 9 | 1693 | Sun Sep 04, 2016 12:27 pm by brickrider2 |
Swap 85 cams into an 86? Worth it if "free?" (Both are US bikes.)by duck | 1 | 1347 | Wed Aug 31, 2016 11:57 pm by charlie99 |
Oil Leak?by colly | 6 | 4135 | Sat Aug 13, 2016 5:38 am by KiwiK100 |
Exhaust helpby Baur TCAftermarket muffler woes... | 5 | 1564 | Fri Aug 12, 2016 5:34 pm by Two Wheels Better |
Cam Chain Kit - Help, Pleaseby indian036 | 8 | 1687 | Tue Aug 09, 2016 8:14 pm by indian036 |
Fuel Injection system refreshby Roland5How long does it take to refill and re-pressurize the fuel injection system | 13 | 1610 | Tue Aug 09, 2016 4:12 am by 92KK 84WW Olaf |
Copper/bronze flakes in sump - opinions pleaseby 88 | 22 | 3094 | Wed Aug 03, 2016 7:49 pm by 88 |
Pictures of Fuel Line Quick Disconnects on your K100RT?by Roland5Fuel QD | 3 | 1417 | Fri Jul 29, 2016 6:37 pm by Dai |
injector capby andyldean | 8 | 1385 | Fri Jul 29, 2016 6:52 am by Dai |
Water in gearboxby Harry NicholsonWater in gearbox , how | 1 | 1588 | Sat Jul 23, 2016 5:05 am by TacKler |
This must be a bargain.by sidecar paul | 1 | 1382 | Tue Jul 19, 2016 8:30 pm by Rick G |
LE Jetronic injection vs aftermarket ECU and sensors[ 1, 2 ] by HaloDiscussion on Modification to injection system electronics | 80 | 11990 | Fri Jul 15, 2016 1:06 pm by KyleMB |
Fuel Cap stuffby klompy the grey brickbusted tumbler | 20 | 2369 | Fri Jul 15, 2016 5:24 am by 92KK 84WW Olaf |
2 Stroke petrol accidentally put into tank?by FatRakoon | 12 | 1513 | Wed Jul 13, 2016 7:54 am by FatRakoon |
K100RS / Reliant Trike - Speed/Revs question.by FatRakoon | 11 | 1612 | Tue Jul 12, 2016 9:32 am by FatRakoon |
K100RS radiatorby brickrider2How is this removed??? | 22 | 3789 | Mon Jul 11, 2016 5:37 pm by sidecar paul |
Clutch Diaphragm Spring - Which One?by AL-58 | 3 | 1410 | Tue Jul 05, 2016 8:17 am by charlie99 |
Engine cuts out after 20 or so miles.by trikerider81Spark plugs coked up , therefore losing spark | 4 | 1402 | Tue Jul 05, 2016 5:13 am by 92KK 84WW Olaf |
A tale of 5 bricksby AL-58 | 11 | 1481 | Wed Jun 29, 2016 8:04 pm by Rockman |
Rough tickover?by Dai | 0 | 1422 | Sun Jun 26, 2016 4:39 pm by Dai |
K100 gearbox tiny part needed. Selector fork rollerby touchwoodsdenK100 gearbox tiny part needed. Selector fork roller | 4 | 1575 | Tue Jun 14, 2016 6:56 am by Dai |
Camshaft capsby Dai | 8 | 1612 | Mon Jun 13, 2016 6:26 am by Dai |
Crank cover materialby jrocker3235 | 11 | 1424 | Wed Jun 08, 2016 9:19 pm by Holister |
can out of ballance bhtterflys make a rsttle sound at idle?by SniperX | 3 | 1234 | Wed Jun 01, 2016 3:45 pm by KJustin |
Topics [50]
- No new posts
- New posts
- New posts [ Popular ]
- New posts [ Locked ]
