Topics [0]
engine won't run following repairsby kjo | 13 | 1816 | Mon May 30, 2016 4:02 am by charlie99 |
oil/water pump....by SniperX | 8 | 1542 | Wed May 25, 2016 3:49 pm by SniperX |
Clutch arm rubber boot: fitting?by Kyle10 | 6 | 2133 | Mon May 23, 2016 9:37 am by Tomnel |
Oil in the drive shaft housing?? helpby dakelvinatorOil in the drive shaft housing | 20 | 2064 | Sun May 22, 2016 4:24 pm by dakelvinator |
Which grease do I use for the clutch actuating arm?by gabriel | 20 | 2640 | Sun May 22, 2016 4:20 am by Rick G |
Steam engine noiseby HighlyBlessed | 2 | 1264 | Sat May 21, 2016 9:20 pm by HighlyBlessed |
Cylinder head reffiting - best practiceby pond snail | 3 | 1435 | Sat May 21, 2016 8:15 pm by pond snail |
The bike had a little lie down, and now it won't start.by RussK100 | 26 | 1839 | Tue May 17, 2016 9:38 pm by RussK100 |
Performance Enhancement Optionsby Oliveri | 10 | 3403 | Thu May 12, 2016 7:46 pm by Oliveri |
Oil leakage.by electric_monk | 3 | 1279 | Mon May 09, 2016 6:44 am by K75cster |
Back from the mechanics and they can't help. (starting)by YellandRuns fine when hot, takes aerostart to get started cold. | 7 | 1293 | Tue May 03, 2016 6:23 am by 92KK 84WW Olaf |
Thickest valve shim?by feo | 10 | 1585 | Mon May 02, 2016 6:59 pm by Holister |
starts but won't accelerate / rev upby Tony goodwink100 1984 | 8 | 1798 | Thu Apr 28, 2016 8:53 am by Rick G |
State of the Splineby KyleMB | 3 | 1392 | Sun Apr 24, 2016 5:40 am by Rick G |
crank case gasket replcementby 6strings | 2 | 1280 | Sat Apr 23, 2016 7:17 pm by Holister |
Cold startingby riddle the sphinx | 5 | 1322 | Tue Apr 19, 2016 4:38 pm by 92KK 84WW Olaf |
Clutch slipping and juddering on take offby Spicepauladvice | 10 | 2652 | Tue Apr 19, 2016 1:01 pm by Dai |
No Drive to rear wheelby K100LT NottsSudden loss of drive with no noise | 7 | 1945 | Mon Apr 18, 2016 9:47 pm by K75cster |
Throttle response[ 1, 2 ] by Beamer | 59 | 6327 | Thu Apr 14, 2016 10:38 am by Point-Seven-five |
Oil/water pump seals replacement[ 1, 2, 3 ] by MT350Explorer | 104 | 11800 | Thu Apr 14, 2016 12:36 am by Rick G |
Timing chain replacement what section and page in the manual?by SniperX | 3 | 1584 | Fri Apr 08, 2016 9:48 pm by Rick G |
Intermittent loss of throttle. (Feels like I'm running out of gas)by desperado | 16 | 1584 | Fri Apr 08, 2016 5:02 pm by Holister |
Final shaft oil changeby piseth | 3 | 2577 | Thu Apr 07, 2016 12:46 pm by piseth |
Injectors + rail £42 all inby Dai | 0 | 1198 | Sun Apr 03, 2016 7:45 am by Dai |
Stuck drive shaftby mikerogers74 | 13 | 1907 | Fri Apr 01, 2016 3:41 pm by Born Again Eccentric |
Mystery tubeby Bikesmith | 4 | 1464 | Thu Mar 31, 2016 9:11 pm by blaKey |
Again K1200 rear wheel on early K100by PiotrK100 | 0 | 1415 | Sat Mar 26, 2016 2:31 pm by PiotrK100 |
leaking bolt near water pumpby Paul Fridayleaking bolt | 9 | 3035 | Sun Mar 20, 2016 9:13 pm by K75cster |
K1200 oil/water pump on K1100. Has anyone ever managed it?by Motorbike Mike | 1 | 1883 | Sat Mar 19, 2016 10:08 am by Motorbike Mike |
BULK OIL PURCHASE OPPORTUNITY - Aussies onlyby Holister | 2 | 1386 | Thu Mar 17, 2016 9:10 pm by Holister |
valve lash check on K100 2-valve enginesby brickrider2How often? | 14 | 4112 | Wed Mar 16, 2016 11:59 pm by Rick G |
Low powerby diveshadow | 12 | 2206 | Mon Mar 14, 2016 5:47 am by Holister |
repairing oil pressure sender wire?by kstarrepairing oil pressure sender wire? | 5 | 1610 | Sat Mar 12, 2016 10:54 am by kstar |
Gluing a bearing in placeby Kyle10 | 10 | 3340 | Sat Mar 12, 2016 5:53 am by smoll1 |
Summer thermo for K100RT?by SniperX | 11 | 2041 | Mon Mar 07, 2016 7:40 pm by Rick G |
Doing the timing chain next, questions....by SniperX | 3 | 1599 | Mon Mar 07, 2016 9:59 am by Holister |
Transmission!by bolka13 | 7 | 3218 | Tue Mar 01, 2016 3:43 pm by 92KK 84WW Olaf |
Three and a half cylinders and a diesel knock knock knock knock.......by Dai | 25 | 2174 | Wed Feb 24, 2016 6:29 pm by Chocolate |
Cooling system questionsby SniperX | 3 | 1401 | Wed Feb 24, 2016 3:15 am by charlie99 |
Oscillator circuit for testing fuel injectors?by Dai | 3 | 1621 | Sun Feb 21, 2016 6:20 pm by Dai |
Measurements of K1100 Throttle Bodiesby GalvanicNeed some specific measurements for a special project. | 9 | 4973 | Thu Feb 18, 2016 11:16 pm by Kyle10 |
Rattly timing chainby Holister | 26 | 3845 | Wed Feb 17, 2016 12:53 am by indian036 |
FD input seal leakingby Holister | 19 | 1872 | Tue Feb 09, 2016 7:53 am by Rick G |
k75 pistons in k100by jjs1234Been searching for info on this... | 18 | 2430 | Wed Feb 03, 2016 10:49 am by charlie99 |
How far into clutch driven friction plate should gearbox splines on K100 go?by touchwoodsdenHow far into clutch driven friction plate should gearbox splines on K100 go? | 6 | 1871 | Sun Jan 24, 2016 7:57 pm by touchwoodsden |
K100 8v Motad silencer. Does anyone have an opinon?by Motorbike Mike | 4 | 1742 | Fri Jan 15, 2016 8:57 pm by Two Wheels Better |
engine oil filterby piseth | 21 | 3895 | Fri Jan 15, 2016 6:34 am by energyhutch |
Gear Lever advice sort.by Englishstiv | 12 | 3522 | Tue Jan 12, 2016 7:00 pm by Englishstiv |
Fuel filter routine replacement - necessary?by Snod Blatter | 18 | 2470 | Thu Dec 31, 2015 11:47 pm by beanoldboy |
Final Drive Check for Bearing Wearby Packo | 2 | 1554 | Thu Dec 31, 2015 5:31 pm by sidecar paul |
Topics [50]
- No new posts
- New posts
- New posts [ Popular ]
- New posts [ Locked ]
