Topics [0]
Starting without original speedometerby Laapottijstart working engine turning but not starting | 13 | 2312 | Thu Aug 10, 2017 8:28 pm by 92KK 84WW Olaf |
Solid non-flashing ABS light in cluster (K1100 ABS I)by duck | 1 | 1159 | Thu Aug 10, 2017 12:40 pm by Point-Seven-five |
A shout to the Irish!by club_c | 3 | 1151 | Tue Aug 08, 2017 6:09 am by 92KK 84WW Olaf |
Do all K models have self canceling turn singals?by boostd4 | 1 | 1166 | Sat Aug 05, 2017 3:28 pm by duck |
Help needed - sudden troubles with starter motor, front light & instruments lightsby ffbikersaEngine won't start, lights go off | 7 | 1369 | Fri Aug 04, 2017 5:46 pm by ffbikersa |
gearshift decoding for aftermarket instrumentsby charlie99 | 34 | 10886 | Fri Jul 28, 2017 3:11 am by maz_dede |
Upgrading the headlightby MD K100RS | 18 | 2888 | Wed Jul 26, 2017 11:59 am by 92KK 84WW Olaf |
fuel pump power diagnosisby kstarfuel delivery electrical issue... | 5 | 1272 | Fri Jul 21, 2017 4:15 pm by robmack |
ACEWELL 2853 START ENABLEby AndrewPFlasher relay clicking no start | 0 | 1555 | Wed Jul 12, 2017 11:50 pm by AndrewP |
Force fan to stay on or add a switch?[ 1, 2 ] by SniperX | 51 | 4651 | Wed Jul 12, 2017 6:28 pm by Dai |
K100 16V 1991 - no spark to plugs after some modificationsby mquadro | 5 | 1849 | Wed Jul 12, 2017 5:41 pm by mquadro |
Spare partsby timo27 | 2 | 1263 | Sun Jul 09, 2017 5:18 am by timo27 |
Wiring diagramby FreyZI | 3 | 1576 | Fri Jul 07, 2017 8:42 pm by Woodie |
Broken plug capby ush1000 | 2 | 1035 | Fri Jul 07, 2017 3:20 pm by Dai |
low speed cutting out.by bigdavergselectrical | 6 | 1138 | Fri Jul 07, 2017 9:58 am by bigdavergs |
Petrol tank and fuel pumpby timo27 | 6 | 1290 | Tue Jul 04, 2017 4:53 am by Holister |
HELP! Need help in removing front whhel ABS sensor on a 1992 K100RSby commanderdrakoStocked sensor | 4 | 1167 | Sat Jun 24, 2017 3:26 pm by Born Again Eccentric |
1984 K100RT Fuel and running issue.by 92KK 84WW OlafNot running 100% | 5 | 1405 | Thu Jun 22, 2017 1:18 pm by 92KK 84WW Olaf |
High Output H4 bulbsby Gaz | 17 | 2017 | Thu Jun 22, 2017 5:22 am by Dai |
No spark troubleshootingby Bronze Lion | 36 | 4468 | Wed Jun 21, 2017 10:17 pm by Rick G |
electrical help needed urgently.by shipo282 | 14 | 1454 | Wed Jun 21, 2017 7:22 pm by tagaz |
Radio code doesnt workby Rockman | 7 | 1479 | Sun Jun 11, 2017 9:16 pm by 92KK 84WW Olaf |
Where to hook headlight relayby nino | 6 | 1224 | Sat Jun 10, 2017 9:32 pm by Gaz |
What am I forgetting?!? No fuel Pumpby TurboBrick | 5 | 1126 | Wed Jun 07, 2017 5:46 pm by Born Again Eccentric |
Anybody know what triggers the 86+ low fuel light to illuminate?by duck | 2 | 1161 | Mon Jun 05, 2017 9:17 pm by robmack |
Starting the fan replacement tomorrow! Any vids or primers around?by SniperX | 23 | 1405 | Mon Jun 05, 2017 2:10 am by duck |
Erratic Fuel Gauge and Temp Gaugeby blacknailsElectrical Woes | 1 | 1455 | Sun Jun 04, 2017 6:23 pm by robmack |
1994 BMW K1100LT - need help pleaseby GuestWiring wierdness | 5 | 1785 | Thu Jun 01, 2017 2:00 am by Guest |
Charging?by nino | 11 | 1633 | Fri May 19, 2017 6:44 pm by charlie99 |
Wire to headlight socket color?by nino | 8 | 4047 | Fri May 19, 2017 1:01 pm by nino |
Cooling fan issue, faulty temperature sender?by pond snail | 14 | 1661 | Fri May 19, 2017 2:50 am by SniperX |
1985 K100 Yellow wires with D connector out of cluster areaby LaughingGravyWhat is this supposed to connect to? | 9 | 1633 | Wed May 17, 2017 5:32 am by 92KK 84WW Olaf |
Handlebar sizesby Peterk100rsnew bars for my k75s | 7 | 5299 | Mon May 08, 2017 9:36 pm by Gaz |
ABS module/brain ? K100LT 1990by Silver foxABS problem, surprise, surprise..... | 20 | 1807 | Sun May 07, 2017 3:15 pm by Born Again Eccentric |
When should this bulb be on?by Bucky#13 above headlight | 6 | 1189 | Sun May 07, 2017 9:19 am by Bucky |
petrol pumpby trikernon starter | 45 | 1460 | Fri May 05, 2017 6:34 pm by K75cster |
Removing or Pushing Out the Fuse Box To Access the Backby Shep | 5 | 1475 | Fri Apr 28, 2017 9:07 pm by Dai |
Apparently unseen electrical malfunctionby QuistStarting issues when Airflow meter or Heat sensor unit attached. | 33 | 1950 | Mon Apr 24, 2017 10:17 am by Point-Seven-five |
Hazard lights coming on when I indicate right and sometimes leftby Peterk100rs | 1 | 1044 | Sun Apr 23, 2017 4:20 am by Rick G |
Start issues fuse 5by leon83fuse 5 blows every time I hit the start button | 11 | 1285 | Sat Apr 22, 2017 9:53 am by Inge K. |
K100rs cafe racer speedoby tyetye | 1 | 1283 | Thu Apr 20, 2017 8:10 am by blaKey |
Little green starter Buttonby cliverockyLittle green starter Button | 7 | 1690 | Thu Apr 20, 2017 8:05 am by blaKey |
Headlight Flickering over 4k revsby TheJoker | 7 | 1390 | Thu Apr 20, 2017 5:56 am by KiwiK100 |
Battery, Fully Charge but no life when connectedby elementalfireElectrical Issues | 3 | 1231 | Wed Apr 19, 2017 1:07 pm by Bumblebee |
K100rs flat spot mid rangeby tyetye | 0 | 1117 | Wed Apr 19, 2017 12:10 pm by tyetye |
ABS Wiringby AndrewPABS wiring removal on 1989 K100RS | 7 | 1601 | Wed Apr 19, 2017 8:14 am by AndrewP |
Starter running until battery is disconnected. One battery boiled already.by TIV | 27 | 2994 | Sat Apr 15, 2017 7:56 pm by pond snail |
removing computerby ARTCOLLINSJRhow to release computer | 6 | 1736 | Sat Apr 08, 2017 7:22 am by Laitch |
Speedo nonsense,by Johnser | 3 | 1149 | Fri Apr 07, 2017 5:14 pm by Johnser |
Coils for 8 valve and 16 valve: interchangeable?by 92KK 84WW OlafCan I put 16 vavle coils in an 8 valve K? | 3 | 1360 | Thu Apr 06, 2017 8:52 pm by Rick G |
Topics [50]
- No new posts
- New posts
- New posts [ Popular ]
- New posts [ Locked ]
