Topics [0]
K100 get rid of the air mass sensor and use K1200 configuration instead???by Atsea | 4 | 4161 | Wed Apr 05, 2017 11:36 pm by Atsea |
Can Anybody Explain?by KafflutPress starter switch while motor running. | 44 | 2557 | Mon Apr 03, 2017 11:59 am by Kafflut |
Relay questionby JHWeathoSwitching from standard bulbs to led indicators | 28 | 4355 | Sun Apr 02, 2017 5:52 pm by Inge K. |
K100 diesel. Fuel pump problem? Original pumpby touchwoodsdenK100 diesel. Fuel pump problem? Original pump | 28 | 2445 | Sat Apr 01, 2017 9:11 am by touchwoodsden |
Battery charging questionby KiwiK100 | 15 | 1653 | Sat Apr 01, 2017 2:48 am by KiwiK100 |
volt gaugeby Viper357 | 19 | 2032 | Fri Mar 31, 2017 1:08 pm by BobT |
ABS 1 Problems - 1993 K1100RSby Pegasus | 0 | 1275 | Thu Mar 30, 2017 9:34 am by Pegasus |
Flooding, injectors open but not pulsing, Solved.by LuckyK100rs flooding on startup after being sitting for a number of years. | 8 | 1669 | Wed Mar 29, 2017 7:30 am by Dai |
K75 RT 1995 computer plugby GrahameJammed plug | 4 | 1132 | Tue Mar 28, 2017 5:20 pm by Point-Seven-five |
Instruments wiring adviceby FreyZIwiring aftermarket speedo | 8 | 2654 | Mon Mar 27, 2017 1:27 pm by Dai |
K100 Ignition Switch Replacementby Gee | 5 | 6000 | Mon Mar 13, 2017 4:29 pm by Gee |
Gear selection indicator replacementby JohnserChanging the stock LCD gear indicator for a new LED one | 23 | 3327 | Sun Mar 12, 2017 9:39 am by Johnser |
Chinese injectorsby nino | 5 | 1573 | Sat Mar 11, 2017 5:05 am by Chocolate |
"calling all cars, calling all cars" - It's fix it timeby werewasi | 24 | 1782 | Sat Mar 11, 2017 12:56 am by charlie99 |
RT wont startby AL-58 | 5 | 1435 | Sat Mar 11, 2017 12:44 am by charlie99 |
Ignition switchby audibob | 7 | 1455 | Wed Mar 08, 2017 2:12 pm by BobT |
Fuel Injector plastic eletrical clipby MikeisonTV | 4 | 1117 | Sat Mar 04, 2017 8:38 pm by charlie99 |
Indicators stopped working after rain??by Bonzo | 17 | 2384 | Sat Mar 04, 2017 12:33 pm by Bonzo |
Hall Sensor Replacement - need to replace entire harness?by timz10000 | 6 | 3024 | Sun Feb 26, 2017 10:14 pm by Holister |
What am I missing?by genewilliamsgeneuplugged connectors | 11 | 1295 | Thu Feb 23, 2017 6:34 pm by BobT |
Fuel pump woes (again)by RussK100 | 29 | 1811 | Wed Feb 22, 2017 5:34 pm by sidecar paul |
Does these relays work?by jtssviggum | 0 | 1149 | Tue Feb 21, 2017 4:27 pm by jtssviggum |
Circuit board and gen-lightby jtssviggum | 6 | 1620 | Tue Feb 21, 2017 1:34 pm by jtssviggum |
Strange Rear Lightsby indian036 | 1 | 1189 | Sun Feb 19, 2017 8:05 pm by blaKey |
LED turn signals and relaysby jtssviggum | 2 | 4257 | Wed Feb 15, 2017 12:20 pm by Chocolate |
No name speedometerby Jonas BodinHave seen this instrument on a bunch of K's. Hope to collect knowledge about what to think of here! | 4 | 1769 | Tue Feb 14, 2017 11:55 am by Jonas Bodin |
Hazard lights on??by DavepWhy are all my indicators flashing? | 5 | 1732 | Mon Feb 13, 2017 3:51 pm by Davep |
Installing BMW Heated Gripsby rob_gordon | 29 | 4659 | Sun Feb 12, 2017 10:08 pm by Gaz |
IGNITIONby fleaIGNITION PROB | 23 | 2550 | Mon Feb 06, 2017 4:32 am by charlie99 |
Fuse F1 and F6 Blowing on 92 K100RSby qkellybypassed fuel pump | 2 | 1245 | Sun Feb 05, 2017 12:07 am by charlie99 |
Gearbrake?by Bikesmith | 16 | 1300 | Wed Feb 01, 2017 7:25 pm by Bikesmith |
odometerby wickystopped working | 8 | 1712 | Fri Jan 27, 2017 4:15 am by blaKey |
Recommendations on aftermarket speed/tachoby FreyZIGauges help please | 0 | 1187 | Thu Jan 26, 2017 7:21 pm by FreyZI |
Aftermarket speedoby 6strings | 11 | 6107 | Wed Jan 25, 2017 4:31 pm by FreyZI |
Tail light questionby nods | 11 | 1466 | Wed Jan 25, 2017 6:29 am by nods |
Current testerby Albyalbatross1A usefull cheap test tool | 12 | 2975 | Mon Jan 09, 2017 10:31 am by Point-Seven-five |
Instruments compatibility?by nino | 6 | 1875 | Sat Dec 31, 2016 10:13 am by robmack |
FUEL SENDER UNITby Mick S | 5 | 1698 | Thu Dec 29, 2016 6:15 pm by Holister |
Starter button bypassby cliverocky | 2 | 1343 | Wed Dec 28, 2016 12:41 am by Holister |
Another Fan Replacementby Gaz | 3 | 1441 | Wed Dec 14, 2016 11:23 am by Point-Seven-five |
K1100 O2 sensor kaputby Holister | 10 | 2316 | Tue Dec 13, 2016 7:46 pm by Holister |
Instrument cluster lightsby Garyk100Tachometer not illuminating | 4 | 1888 | Mon Dec 12, 2016 10:41 pm by Garyk100 |
Odyssey battery PC680by jolo994Can this battery work sideways? | 3 | 1495 | Mon Dec 12, 2016 8:33 pm by jolo994 |
none lead-acid battery options for bricksby Beamer | 31 | 1761 | Sat Dec 10, 2016 8:07 am by Snod Blatter |
speedo and instrument connectionsby charlie99a cleanup of the connectors ..trying to solve intermittent speedo | 40 | 6159 | Wed Dec 07, 2016 10:19 am by jenkinskg |
Right hand light switch slider .by filasteinHow to re-mantle the switch | 7 | 1563 | Tue Dec 06, 2016 1:30 am by Rick G |
Alternator lightby hesviliSimple solution? | 3 | 1387 | Sat Dec 03, 2016 3:20 am by hesvili |
Lead on plug leadby Stanspark plug problem | 22 | 1884 | Thu Dec 01, 2016 11:16 pm by Laitch |
85 Instrument lightsby SteveFord | 7 | 1426 | Mon Nov 28, 2016 8:55 am by Dai |
Speedo reading low, variableby Rockman | 12 | 1477 | Tue Nov 22, 2016 10:57 pm by charlie99 |
Topics [50]
- No new posts
- New posts
- New posts [ Popular ]
- New posts [ Locked ]
