Topics [0]
The difference a few decades can makeby Bikesmith | 3 | 1378 | Wed Apr 20, 2016 7:21 pm by Dale S |
Fuse 2 blowingby Born Again Eccentric | 9 | 2341 | Wed Apr 20, 2016 4:46 am by Beamer |
Which Batteryby Johnny kiddBattery query | 14 | 1788 | Wed Apr 20, 2016 1:46 am by GF Wollongong |
Bad Flasher Relay?by Bikesmith | 3 | 2107 | Tue Apr 19, 2016 1:53 am by KJustin |
1-4 non-firing still/againby KJustin | 16 | 1669 | Mon Apr 18, 2016 7:39 pm by robmack |
Low power/possible coil problem--help needed **SOLVED**by KJustin | 47 | 5203 | Mon Apr 18, 2016 10:27 am by Holister |
Minor head-scratcher with the BMUby Dai | 2 | 1231 | Sun Apr 17, 2016 1:58 pm by Dai |
Hall Effect Sensor questions **SOLVED**by KJustin | 38 | 9648 | Sun Apr 17, 2016 3:44 am by Holister |
k100 1984by Tony goodwinstarts and only idles | 1 | 1369 | Fri Apr 15, 2016 8:32 am by 92KK 84WW Olaf |
Flowmeter restoration[ 1, 2 ] by Beamer | 68 | 7085 | Tue Apr 12, 2016 7:56 pm by Beamer |
Bosch air flow meter version differencesby Beamer | 4 | 3344 | Mon Apr 11, 2016 3:04 am by Beamer |
Fuel gauge level sending unit resistanceby kioolt | 4 | 2245 | Sun Apr 10, 2016 9:21 pm by Rick G |
Faulty Rev Counterby rob_gordon | 12 | 1647 | Wed Apr 06, 2016 5:32 am by charlie99 |
As Time Goes Byby Ajaysstill composing..! | 8 | 1352 | Mon Apr 04, 2016 7:28 pm by K75cster |
need a buttonby AjaysStarter button | 3 | 1260 | Mon Apr 04, 2016 4:18 am by Ajays |
Fuel pump woesby Bikesmith | 18 | 2997 | Sat Apr 02, 2016 11:23 am by Point-Seven-five |
Hall effect sensor testing.by Beamer | 22 | 6829 | Fri Apr 01, 2016 9:37 pm by Crazy Frog |
Light telltale malfunction?by Bikesmith | 3 | 1379 | Wed Mar 30, 2016 4:16 pm by Bikesmith |
Mystery connectorsby Bikesmith | 2 | 1399 | Wed Mar 30, 2016 2:12 pm by Bikesmith |
Intermittent cut outsby Beamer | 8 | 1543 | Tue Mar 29, 2016 9:34 pm by Beamer |
get off abs from k1100 PLEASE HELPby ranfart | 1 | 1247 | Fri Mar 25, 2016 11:03 pm by Point-Seven-five |
OK, HTF do I get the headlight lamp out?by SniperX | 24 | 1637 | Wed Mar 23, 2016 10:10 pm by Holister |
Intermittent electrical gremlinby Rockman | 2 | 1295 | Sun Mar 20, 2016 6:21 pm by Rockman |
Instrument panelby emmanuelfiadjoeGoes off when I switch headlight on | 12 | 1521 | Fri Mar 18, 2016 1:03 pm by emmanuelfiadjoe |
Bike doesn't startby energyhutch | 8 | 1531 | Sun Mar 13, 2016 1:38 pm by ReneZ |
Turn signal plugby nvboyTurn signal plug rewiring | 14 | 2216 | Sat Mar 12, 2016 8:51 am by Brad-Man |
neutral light?by Ken52neutral light stays on, | 3 | 1518 | Fri Mar 11, 2016 8:15 am by Holister |
Dash pad accessory switchby KeithKLooking for input on adding an accessory switch to the dash pad | 8 | 1888 | Wed Mar 09, 2016 1:11 pm by KeithK |
Sensor? | electric contact cleaning/maintenanceby Chocolateelectric contact cleaning sensor? | 10 | 3666 | Mon Mar 07, 2016 10:33 am by Point-Seven-five |
Any thoughts on lithium batteries?by 6strings | 7 | 2184 | Sun Mar 06, 2016 10:06 pm by indian036 |
Starter relay failed?...what do you think?by Nigel T | 6 | 2149 | Sun Mar 06, 2016 5:35 pm by Nigel T |
Intermittent Power Issuesby papajhotelGremlins | 12 | 1660 | Thu Mar 03, 2016 2:34 pm by Sagi |
Load shed relay - how to permanently remove from loom?by half brick | 7 | 2498 | Wed Mar 02, 2016 5:37 pm by half brick |
which batteryby playlikewedreambattery for k75 | 22 | 1937 | Wed Feb 24, 2016 6:16 pm by blaKey |
Whats the least CCA I need in a battery for an 8v K100?by half brick | 2 | 2120 | Wed Feb 24, 2016 3:29 pm by half brick |
Gear Indicatorby Rockman | 1 | 1348 | Tue Feb 23, 2016 8:49 pm by duck |
Clock repairby sidecar paul | 8 | 3560 | Tue Feb 23, 2016 5:28 pm by 92KK 84WW Olaf |
K75c speedo has stopped workingby fatdog | 5 | 1651 | Fri Feb 19, 2016 5:22 am by 92KK 84WW Olaf |
Headlamps relays - mounting point?by Nigel T | 32 | 2118 | Wed Feb 17, 2016 5:32 pm by Nigel T |
Another possible solution to the corroded brakeswitch problemby Dai | 8 | 1629 | Tue Feb 16, 2016 5:26 am by 92KK 84WW Olaf |
K1100rs plug leadsby 88 | 15 | 1500 | Wed Feb 03, 2016 6:47 pm by Holister |
Part of early K100 loom wanted.The fuel tank loom part of the electrical 4 pin round socket.by touchwoodsdenHelp please | 2 | 1450 | Sun Jan 31, 2016 12:20 pm by touchwoodsden |
Hall sensor, tachometer, or something else entirely?by Rabidchiwawa007 | 2 | 1583 | Sun Jan 31, 2016 3:31 am by Rick G |
faulty speedometerby Holister | 18 | 2285 | Wed Jan 27, 2016 1:33 pm by Crazy Frog |
Relay Identificationby Big GRelay Identification | 6 | 8333 | Sat Jan 23, 2016 10:31 am by Point-Seven-five |
Trouble shooting ABS on a K1 1990by playlikewedreamfind the fault | 2 | 2752 | Fri Jan 22, 2016 12:05 am by Chocolate |
electric diagrams for K1by playlikewedream | 8 | 1634 | Mon Jan 18, 2016 6:12 pm by playlikewedream |
Repairing left switch blockby Gaz | 8 | 3150 | Sat Jan 16, 2016 6:42 am by Gaz |
ECU groundingby diveshadow1996 K1100LT 0302263 | 6 | 1983 | Wed Jan 13, 2016 5:58 am by Rick G |
Fuel Injector Questionby energyhutch | 5 | 1517 | Tue Jan 12, 2016 1:22 am by Holister |
Topics [50]
- No new posts
- New posts
- New posts [ Popular ]
- New posts [ Locked ]
