Topics [0]
Cold Start Difficultyby KafflutCold start problems I had went away after a 50km ride | 5 | 1524 | Wed May 30, 2018 6:07 pm by ERasberg |
Mixing coolantsby jscharaMixing coolants | 3 | 999 | Wed May 30, 2018 3:42 am by MartinW |
Non Starterby CraigNZK100 RS | 45 | 1644 | Sat May 26, 2018 9:31 pm by CraigNZ |
Which clutch plateby nino | 6 | 1045 | Sat May 26, 2018 3:36 pm by Dai |
Source for valve shims?by timz10000 | 1 | 1016 | Sat May 26, 2018 2:03 am by Rick G |
Engine interruptionsby George_Pap | 41 | 1428 | Tue May 22, 2018 1:01 pm by George_Pap |
How to remove Oetiker clipsby nods | 7 | 1194 | Mon May 21, 2018 6:46 pm by nods |
Adding extra gauges - Oil pressure - Volts.......by Mark K Boy | 23 | 3049 | Sun May 20, 2018 6:00 pm by Mark K Boy |
Water Temp Sensorby Trapper | 7 | 1469 | Sun May 20, 2018 8:48 am by Dai |
Air screw balancingby nobbylon | 5 | 1182 | Sat May 19, 2018 12:23 pm by nobbylon |
Performance chipsby TheGreatMorten | 3 | 1600 | Sat May 19, 2018 1:59 am by duck |
Gearbox input spline lubeby audibob | 5 | 1433 | Wed May 16, 2018 4:43 am by audibob |
k75 vs k100 cam chain tensionerby audibob | 12 | 2404 | Tue May 15, 2018 10:19 am by audibob |
Installing a new clutch cable.by Tesla13BMW | 23 | 2292 | Sun May 13, 2018 12:54 am by Tesla13BMW |
Timing chain noiseby audibob | 6 | 2371 | Fri May 11, 2018 9:48 am by audibob |
'87rs Driveshaft failure, Swingarm rupture, strut saved my lifeby wallyduke | 19 | 1528 | Tue May 08, 2018 9:18 pm by wallyduke |
Exhaust Nuts and Washersby Rickmeister | 18 | 2100 | Sat May 05, 2018 3:55 pm by Dai |
Air Filter Replacement (needed)?by George_Pap | 17 | 1339 | Thu May 03, 2018 12:41 am by George_Pap |
Swingarm Disassembly & Proper lubricationby George_Pap | 42 | 2197 | Wed May 02, 2018 8:26 am by George_Pap |
screaching sound at 3000-4000 rpmby nobbylon | 26 | 1543 | Sat Apr 28, 2018 4:37 am by nobbylon |
Throttle not returning fully closed!by eman-nyc | 8 | 1222 | Thu Apr 26, 2018 9:09 am by duck |
Oil pressure light after water pump replacementby Postmanhelp | 6 | 1237 | Mon Apr 23, 2018 1:44 pm by Postman |
What does it mean that most of my valve clearances are tightby FreyZI | 22 | 3683 | Sun Apr 22, 2018 8:50 pm by Dai |
Rear wheel wobbleby Snod Blatter | 35 | 2682 | Sun Apr 22, 2018 5:10 pm by Dai |
K series exhaust headers cracking? A possible prevention.by Motorbike Mike | 11 | 2828 | Sun Apr 22, 2018 2:19 pm by duck |
valve clearanceby mister_anger | 9 | 1660 | Sun Apr 22, 2018 9:04 am by glennpm |
Oil leak from oil pressure sensor wire holeby scottiesharpe | 34 | 11184 | Sun Apr 22, 2018 7:28 am by Dai |
Stuck in 4th gearby Tom Witt | 15 | 3048 | Mon Apr 16, 2018 12:25 pm by caveman |
Throttle Stumbleby flyinglowHesitation off idle | 15 | 2615 | Tue Apr 10, 2018 3:42 pm by flyinglow |
blown headby kevinryuI think I've blown my head, can I fix this? | 10 | 1542 | Mon Apr 09, 2018 4:30 am by charlie99 |
Fuel leakby FreyZI | 12 | 1320 | Sun Apr 08, 2018 9:09 pm by Dai |
Engine case and cover tolerancesby FreyZIHow much is too much? | 8 | 1371 | Sun Apr 08, 2018 5:07 pm by Laitch |
Final drive bearing playby EnJCoopDoes anyone have any useful tips for how to renew the final drive bearing? | 4 | 1282 | Sun Apr 08, 2018 4:48 pm by 92KK 84WW Olaf |
Rebuild kits?by jmccrary | 3 | 1144 | Thu Mar 29, 2018 1:26 pm by jmccrary |
A party inside the shaft driveby StefanMajonezMy K1100LT shaft is properly shafted | 18 | 1979 | Sun Mar 25, 2018 7:42 pm by redrockmania |
fuel pump widget?by Beamer | 18 | 1459 | Sun Mar 25, 2018 3:43 pm by Beamer |
Another hard starting problemby glennpmTrying to get my K100RS back on the road | 38 | 3907 | Sun Mar 25, 2018 3:36 pm by Point-Seven-five |
Clutch actuation pushrod sealby @kustom_moto | 7 | 2128 | Tue Mar 20, 2018 1:08 pm by brickrider2 |
General Durability of the early K100 Drivetrainsby brickrider21985 K100RT | 3 | 1320 | Sun Mar 18, 2018 11:02 pm by 92KK 84WW Olaf |
Where did this come from?by audibob | 3 | 1131 | Sat Mar 17, 2018 1:58 pm by audibob |
Fuel Pump Vibration Damper Gasketby flyinglowCorrect Part Question | 2 | 1727 | Wed Mar 14, 2018 12:21 pm by flyinglow |
K100 starts and diesby GeorgeW50K100 8-valve starts well and then dies straigt away | 19 | 7452 | Sun Mar 04, 2018 12:22 pm by glennpm |
Back pressureby timo27 | 11 | 1320 | Sat Mar 03, 2018 2:27 pm by Two Wheels Better |
Gearbox/transmission bearingsby smoll1 | 14 | 2003 | Sat Mar 03, 2018 7:19 am by smoll1 |
Replacing a leaky fuel line and curious what company it is attached toby MikeisonTV | 6 | 1322 | Fri Mar 02, 2018 3:49 pm by 92KK 84WW Olaf |
Collapsing Fuel Return Lineby MartinW | 14 | 1921 | Thu Mar 01, 2018 1:39 pm by Two Wheels Better |
Running like a pig, and I'm out of ideas.by Beamer | 23 | 1421 | Wed Feb 07, 2018 1:10 pm by Beamer |
K1100LT Gear Position Sensor (GPS) replacementby Guest | 16 | 3469 | Sat Feb 03, 2018 7:39 am by Dai |
Temp sensor lights and then coolant leaks from Thermostat housingby timz10000 | 12 | 1408 | Sun Jan 21, 2018 1:49 pm by timz10000 |
Replaced Hall sensor and bike won't start at allby timz10000 | 15 | 3046 | Sun Jan 14, 2018 5:26 pm by timz10000 |
Topics [50]
- No new posts
- New posts
- New posts [ Popular ]
- New posts [ Locked ]
