Topics [0]
Sprags and HESby Point-Seven-five | 6 | 1051 | Tue Feb 14, 2023 3:41 am by robmack |
K100 Final Drive Modification .. A 2.54 Ratio Bevel Driveby KafflutI'm posting this on behalf of my friend Phil Moser, K100 enthusiast and engineer | 2 | 1403 | Tue Jan 31, 2023 10:01 pm by duck |
oil on r/h side of pumpby tinyspuds | 22 | 1535 | Sun Jan 29, 2023 2:10 am by tinyspuds |
Clymer water/oil pump bolts errata!by tinyspuds | 0 | 1217 | Thu Jan 05, 2023 8:10 am by tinyspuds |
Replace K100 AFM by a MAFby jcd06 | 13 | 2626 | Thu Dec 29, 2022 10:11 am by jcd06 |
Rubber boot clutch arm - Perhaps a dumb questionby long way from homeOil leaking from... | 4 | 1234 | Thu Dec 22, 2022 6:24 pm by long way from home |
Looking for driveshaftby Wirelic20 spline driveshaft needed | 1 | 1221 | Thu Dec 15, 2022 5:03 pm by Laitch |
Fuel Injection Pipe at Front of Railby CraigNZ | 22 | 2129 | Wed Dec 14, 2022 9:31 am by Point-Seven-five |
mechanical noiseby attitudemechanical noise every 10 seconds at idle- K1100LT 1996 | 7 | 1306 | Tue Dec 13, 2022 9:27 pm by 92KK 84WW Olaf |
Cleaning The Fuel Railby jjefferiesHow to go about cleaning the fuel rail of a K75/K100 | 2 | 1312 | Sat Dec 10, 2022 3:08 pm by jjefferies |
Moisture on splinesby tinyspuds | 2 | 1131 | Mon Dec 05, 2022 10:55 am by tinyspuds |
K1100 k100 k75 hybrid engineby crimona | 2 | 1392 | Wed Nov 16, 2022 1:30 pm by crimona |
Clutch plate options - your experienceby redrockmaniaHow does your clutch plate performs and lasts | 0 | 1223 | Sun Nov 06, 2022 6:43 pm by redrockmania |
Throttle cables K100 pre 1986 vs 1986 and afterby jjefferies | 4 | 1458 | Fri Nov 04, 2022 4:03 pm by jjefferies |
Coolant Changeby yamaguzzi | 5 | 1296 | Tue Nov 01, 2022 5:39 pm by MartinW |
K75 gear box/clutch clanging noise.by Kim Hunter | 27 | 1692 | Sat Oct 29, 2022 12:27 pm by Laitch |
K1100 Engine into a K100?by tjh1985 | 4 | 1658 | Wed Oct 26, 2022 3:20 pm by duck |
K100 with high fuel consumption[ 1, 2 ] by ouafnico | 77 | 2737 | Sun Oct 23, 2022 9:44 am by Point-Seven-five |
Klunky Throttleby fishboy316 | 2 | 1104 | Wed Oct 19, 2022 4:43 pm by fishboy316 |
Starter Motor Oil Seal Replacementby vttownie | 7 | 1271 | Thu Oct 13, 2022 1:44 pm by Point-Seven-five |
K75 fuel pump and fuel pick up.by Kim HunterLess km travelled than expected before running out of fuel | 11 | 1556 | Tue Oct 11, 2022 8:34 pm by Kim Hunter |
K100 only runs when injectors are out.by Beamer | 25 | 1560 | Fri Oct 07, 2022 1:11 pm by Beamer |
Clutch Doesn't Disengageby dnkn | 15 | 1385 | Fri Oct 07, 2022 6:02 am by IainM |
'87 K100 Smoke - from engine cover?by vttownie | 18 | 1448 | Fri Sep 23, 2022 10:38 am by Point-Seven-five |
Throttle Locking Boltby bmwk100rs | 7 | 1420 | Fri Sep 23, 2022 2:19 am by sydnorton |
k100 final drive leak, with new output sealby Tommy2305 | 18 | 2014 | Tue Sep 20, 2022 4:12 pm by gvm |
Rubber Gasket Ring failureby redrockmaniaPre 04/1985 K100 Fuel Gauge sealing gasket ring turned to mush | 2 | 1101 | Thu Sep 15, 2022 2:57 am by redrockmania |
'87 K100 No Start Issueby vttownie | 17 | 1650 | Mon Sep 12, 2022 8:32 pm by vttownie |
1 hole Vs 4 hole injectors[ 1, 2 ] by Holister | 62 | 13585 | Tue Sep 06, 2022 8:16 am by jcd06 |
1988 K100 Engine Idleby ush1000 | 3 | 1116 | Sun Sep 04, 2022 3:07 am by Rick G |
Coolant Change...by bmwk100rs | 4 | 1547 | Sun Sep 04, 2022 2:29 am by bmwk100rs |
1988 K100 Engine oil leakby ush1000 | 3 | 1226 | Sat Sep 03, 2022 12:05 pm by ush1000 |
K100/R11XX transmission output splinesby arbalestCompatible/same? | 0 | 1109 | Thu Sep 01, 2022 4:18 pm by arbalest |
drivetrain lubricationby arbalestfinal drive/driveshaft/transmission spline lubrication | 4 | 980 | Fri Aug 26, 2022 9:03 pm by arbalest |
How much force to twist the throttle?by bmwk100rs | 9 | 1109 | Sun Aug 21, 2022 2:47 am by MartinW |
Need help with 87 K75 - all elements for engine start present but won't start. What am I missing?by robmack | 23 | 1500 | Mon Aug 15, 2022 6:23 pm by Arlina |
Regrinding a crankshaft.by UnipowerGT | 4 | 946 | Fri Aug 05, 2022 2:15 pm by Dai |
Inside my K75 final drive!?by MMM - from SeattleDamage or something else? | 2 | 970 | Sat Jul 30, 2022 8:31 pm by MMM - from Seattle |
crankcase coverby madhatter | 3 | 916 | Sun Jul 24, 2022 10:39 pm by madhatter |
clutch friction plate wearby madhatter | 4 | 887 | Sun Jul 24, 2022 10:36 pm by madhatter |
Fuel Injectors Empty Fuel Injectorsby pendullumxFuel Injectors Empty Fuel Injectors | 2 | 956 | Fri Jul 22, 2022 7:57 am by Porto |
K75 - Cold throttle hesitation - stumble.by cobaltc4sCold throttle response hesitation and stumble | 6 | 1092 | Thu Jul 21, 2022 1:44 pm by 92KK 84WW Olaf |
Oil leak from exhaust manifoldby alin2em15 | 6 | 1294 | Wed Jul 06, 2022 12:44 pm by 92KK 84WW Olaf |
Air Box to Pod Filterby Fw66Questions on the conversion | 15 | 6649 | Wed Jul 06, 2022 11:36 am by RS Rider |
Is It Possible?by tjh1985Clutch Swapping | 2 | 773 | Mon Jun 27, 2022 10:11 pm by 92KK 84WW Olaf |
Break downby RomilleIntermittent problem | 5 | 945 | Thu Jun 23, 2022 9:58 am by Point-Seven-five |
Temp gauge n/wby fishboy316 | 3 | 1009 | Mon Jun 20, 2022 10:29 am by fishboy316 |
oil on top of my motorby fishboy316 | 10 | 879 | Thu Jun 09, 2022 10:27 pm by fishboy316 |
K75 Muffler Life Expectancyby Point-Seven-five | 16 | 1204 | Thu Jun 09, 2022 11:13 am by JohnnyMac |
Starter or Sprag clutch failure[ 1, 2, ... , 4, 5 ] by Danish bikerBeen there done that | 222 | 9068 | Mon May 30, 2022 3:30 pm by aakprrt |
Topics [50]
- No new posts
- New posts
- New posts [ Popular ]
- New posts [ Locked ]
