Topics [0]
Starter or Sprag clutch failure[ 1, 2, ... , 4, 5 ] by Danish bikerBeen there done that | 222 | 9138 | Mon May 30, 2022 3:30 pm by aakprrt |
bmw k75 scrambler suspensions?by Lorenzo17advices to get off road | 1 | 857 | Wed May 11, 2022 8:32 pm by Woodie |
Did all fluids except the coolant.by fishboy316 | 12 | 795 | Tue May 10, 2022 3:43 pm by Shep |
Potential choke problem from k1100 throttle body swapby clappy | 15 | 1169 | Sun Apr 17, 2022 12:17 pm by clappy |
1985 K100RS auxiliary driving lights.by RS Rider | 11 | 1364 | Wed Apr 13, 2022 12:52 pm by RS Rider |
retrofit?by arbalestK1200 driveshaft to 20 spline K100 | 9 | 875 | Sun Apr 03, 2022 9:28 am by arbalest |
Too Much Fuel... why?by Chris4n6 | 41 | 1964 | Mon Mar 28, 2022 6:45 pm by Matthew-Brisbane |
Does the Length Matter?by tjh1985Different Clutch Cable Lengths | 4 | 847 | Sun Mar 27, 2022 7:38 am by Woodie |
Low compression on K75by Nom721Poor running at idle and low revs. | 8 | 933 | Tue Mar 15, 2022 12:05 pm by moriarti |
K100 LT info required.by AJR-118 | 5 | 640 | Wed Mar 09, 2022 12:07 pm by AJR-118 |
Idle increase when oil filler cap off[ 1, 2 ] by PortoImproved idle and increase in revs when oil cap off | 65 | 2631 | Wed Mar 09, 2022 6:54 am by Porto |
clean and replace throttle bodies and plenumby tinyspuds | 19 | 2633 | Wed Mar 02, 2022 11:13 am by davemadsen |
Engine barely runningby jjfishing | 5 | 785 | Sun Feb 20, 2022 3:39 pm by jjfishing |
Starting a K100 after long lay offby coopz1985 K100RS | 13 | 1119 | Sun Feb 20, 2022 10:12 am by Point-Seven-five |
Matching gear setsby PackoFinal Drive | 3 | 806 | Mon Feb 07, 2022 1:12 pm by 92KK 84WW Olaf |
Shimming preload in the final driveby halfliveChanging the cover plate from one drive to another | 16 | 2183 | Tue Feb 01, 2022 6:57 am by moriarti |
Oil & Water Pump Drive Shaft Adviceby bmwk100rs | 6 | 1245 | Sun Jan 30, 2022 6:40 am by Dai |
1988 8V K100RS Hi Idle When Hotby blacknailsCold and Hot Idling speeds | 3 | 792 | Tue Jan 25, 2022 3:37 pm by 92KK 84WW Olaf |
K clutch arm pivot bearing removalby attitude | 1 | 851 | Sun Jan 23, 2022 4:08 pm by MartinW |
K100 fuel injector parts.by gabrielK100 fuel injector repairs | 26 | 1482 | Sun Jan 23, 2022 12:47 pm by Point-Seven-five |
1991 K100 LT Intermittent rev limitby slowpoke...... | 10 | 996 | Thu Jan 13, 2022 1:56 pm by slowpoke |
(Maybe)Settling the hotter cams debateby clappy | 14 | 1364 | Tue Jan 11, 2022 4:15 pm by clappy |
clutch arm 10mm shaft lengthby attitudelength difference of 10mm shaft K75 vs K1100 | 7 | 925 | Wed Jan 05, 2022 7:35 pm by Dai |
[solved]Was running fine, but now not.by long way from homeI have fuel and a spark | 25 | 1247 | Wed Dec 22, 2021 6:25 pm by barney t weasel |
Engine doesn't turn overby GergelyExtra friction in engine? Good battery and starter | 12 | 1088 | Sun Dec 19, 2021 4:56 am by Arlina |
Clutch Pushrod Seal Issues - 1994 K75RTby djm_kClutch pushrod seal wont come out and is falling apart | 15 | 1349 | Tue Dec 14, 2021 1:03 am by djm_k |
Starter Bearing Greaseby AUBIEBMWNeed to know what kind of grease for starter bearing | 1 | 863 | Sat Dec 11, 2021 5:16 am by Dai |
Fuel Pump Issuesby yamaguzzi | 15 | 1195 | Thu Nov 25, 2021 6:29 pm by yamaguzzi |
Possibly got water in my gearboxby clappy | 7 | 938 | Wed Nov 24, 2021 11:32 pm by clappy |
Gear lever removalby tinyspuds | 4 | 831 | Tue Nov 23, 2021 2:04 pm by tinyspuds |
cooling fan running constantlyby moriarti | 5 | 577 | Fri Nov 19, 2021 2:49 pm by moriarti |
Storage of Fuel Pump and Fuelby jjefferiesHow to best store a K-75/100 fuel pump | 12 | 965 | Wed Nov 17, 2021 4:47 pm by MartinW |
Diesel oil for oil pump cleaning?by tinyspuds | 11 | 925 | Wed Nov 17, 2021 3:14 pm by tinyspuds |
Which one goes first, the swing arm or the shaft?by bmwk100rs | 18 | 1178 | Sun Nov 14, 2021 8:24 pm by bmwk100rs |
Shaft U-Jointby bmwk100rs | 5 | 1085 | Wed Nov 03, 2021 8:04 pm by AL-58 |
Gearbox no 2nd gearby dallasf | 27 | 1564 | Wed Oct 13, 2021 1:19 am by ausbrick |
6-gear K1100by Arlina | 20 | 3685 | Wed Oct 13, 2021 1:10 am by ausbrick |
Rear main seal replaced twice last Year, Leaking a 3rd time. What am I doing wrong?by sid_knee | 19 | 1742 | Tue Oct 12, 2021 11:39 pm by sid_knee |
What is the thread pitch of the final drive stud bolt?by bmwk100rs | 4 | 964 | Tue Sep 28, 2021 8:28 pm by Laitch |
Apply sealant to the pump mating surfacesby bmwk100rs | 4 | 863 | Sat Sep 25, 2021 9:02 pm by bmwk100rs |
Remove side stand leverby bmwk100rs | 18 | 1098 | Sat Sep 18, 2021 5:17 pm by MartinW |
E10 Fuelby Pete Riley | 12 | 1453 | Mon Sep 13, 2021 9:13 pm by 92KK 84WW Olaf |
K100 Radiator Adviceby jjefferiesNeed to rework Radiator | 21 | 1358 | Mon Sep 13, 2021 1:37 pm by Snod Blatter |
What is this?!by Clintinz | 12 | 1060 | Thu Sep 02, 2021 8:00 am by robmack |
Down Shifting Troubleby tjh1985 | 25 | 1680 | Mon Aug 30, 2021 1:43 pm by 92KK 84WW Olaf |
Cleaning the Oil/Water Pumpby bmwk100rs | 1 | 802 | Sat Aug 28, 2021 6:34 pm by bmwk100rs |
Selector Shaft Outer Diameter?by tjh1985Finding the right part | 12 | 1116 | Sat Aug 28, 2021 2:21 am by poddy |
Clutch Cable - What am I doing wrong?by tjh1985Clutch Lever Range Only 10-12mm | 1 | 914 | Fri Aug 27, 2021 5:17 pm by Point-Seven-five |
Liquid gasket for the water/oil pumpby bmwk100rs | 4 | 767 | Wed Aug 25, 2021 5:13 am by poddy |
Are water/oil pump with two sensors only for California bikes?by bmwk100rs | 2 | 688 | Tue Aug 24, 2021 12:20 am by bmwk100rs |
Topics [50]
- No new posts
- New posts
- New posts [ Popular ]
- New posts [ Locked ]
