Topics [0]
Are water/oil pump with two sensors only for California bikes?by bmwk100rs | 2 | 693 | Tue Aug 24, 2021 4:20 am by bmwk100rs |
Removing the Water/Oil Pump Front Coverby bmwk100rs | 8 | 1069 | Sun Aug 22, 2021 10:17 pm by bmwk100rs |
Clutch Centering Alignment Toolby bmwk100rs | 3 | 969 | Sat Aug 21, 2021 3:59 am by bmwk100rs |
Fuel Pressure Regulator Questionby dwnhillskater | 11 | 966 | Wed Aug 18, 2021 9:25 pm by dwnhillskater |
Fuel leak pressure regulator...by slowandlowHow does FPR work? | 34 | 2288 | Thu Aug 05, 2021 8:49 pm by Beamer |
Removing crankcase lower section (oil sump)by Daytona85 | 2 | 1026 | Thu Aug 05, 2021 6:33 pm by Daytona85 |
Rebuilding/cleaning K100 throttle bodiesby Fentible | 41 | 5452 | Thu Aug 05, 2021 3:03 am by Daytona85 |
Rear Main Seal Leaking[ 1, 2 ] by bmwk100rs | 54 | 3510 | Wed Aug 04, 2021 3:07 am by bmwk100rs |
Can I reverse the Gear Shift Lever?by tjh1985 | 14 | 1380 | Tue Aug 03, 2021 7:42 am by Rick G |
overheating issue remedied?by Spexbike | 24 | 1252 | Sun Aug 01, 2021 4:32 am by Laitch |
update on the fuel pump sagaby Spexbike1985 k100 rs | 10 | 883 | Mon Jul 26, 2021 1:42 pm by robmack |
Aftermarket Supertrapp Repackby zaubertuba | 0 | 626 | Sun Jul 25, 2021 11:25 pm by zaubertuba |
Where does it goby eastern_phoenixMystery pipe | 16 | 2673 | Sun Jul 25, 2021 4:49 am by Spexbike |
Vacuum hose???by gabriel | 15 | 3559 | Sun Jul 25, 2021 4:46 am by Spexbike |
New fuel pump not working ?by Spexbike | 0 | 611 | Sun Jul 25, 2021 4:44 am by Spexbike |
‘92 K75 Alternator drive gear failureby TaosBrick | 25 | 1115 | Thu Jul 22, 2021 12:44 am by MartinW |
Transmission transplant checklist?by KentMTo-do list when trading out transmissions | 4 | 692 | Fri Jul 16, 2021 6:20 pm by Dai |
Hose Replacementby Ecarranza | 5 | 743 | Mon Jul 12, 2021 3:56 am by Ecarranza |
transmission output shaft splineby arbalestquestion | 0 | 680 | Wed Jul 07, 2021 2:35 pm by arbalest |
Radiator oxidationby bmwk100rs | 23 | 1624 | Mon Jul 05, 2021 4:21 pm by Point-Seven-five |
Two Exhaust Pipes Wetby bmwk100rs | 9 | 827 | Sun Jul 04, 2021 8:40 pm by gorio |
Final Drive Splinesby bmwk100rs | 11 | 1280 | Sat Jul 03, 2021 5:28 am by Rick G |
Engine fails to start after rideby jjefferiesRode 26 miles after sitting for 1/2 hour engine failed to start | 3 | 830 | Sat Jul 03, 2021 12:03 am by jjefferies |
output shaft questions[ 1, 2, 3 ] by audibob | 142 | 8667 | Fri Jul 02, 2021 1:49 pm by Laitch |
Surging due to low fuelby jjefferies | 13 | 908 | Tue Jun 29, 2021 11:29 pm by Point-Seven-five |
More transmission issues - need advice[ 1, 2, 3 ] by dallasf | 144 | 3383 | Thu Jun 24, 2021 4:55 am by Laitch |
How to repair rust pits on 85 K100RS headersby AUBIEBMWRust pits on headers need repairing before sending for Jet-Hot coating | 0 | 697 | Sun Jun 20, 2021 10:44 pm by AUBIEBMW |
Sudden Oil Consumptionby John A | 37 | 2194 | Sun Jun 20, 2021 3:43 pm by moriarti |
Valve stem seal installation – can you hammer them on too far?by jns | 10 | 2474 | Sun Jun 20, 2021 2:08 pm by Laitch |
Transmission - Clutch push rod order confirmation (2nd opinion)by dallasf | 8 | 978 | Mon Jun 07, 2021 11:38 pm by Laitch |
Engine Clatter[ 1, 2 ] by MLR | 77 | 9421 | Sun Jun 06, 2021 7:48 am by daveyson |
Engine won't start in cold conditionby efrankAir flow meter related question | 2 | 804 | Sat Jun 05, 2021 4:00 am by Laitch |
High Idle Cable - 2 Positions? Really?by jnclem | 47 | 1322 | Sat May 29, 2021 1:17 pm by jnclem |
1985 K100RS coolant leaking from under filler neck cap.by RS Rider | 17 | 1314 | Fri May 28, 2021 11:44 pm by daveyson |
Oil leak from waterpump areaby DanT56 | 10 | 1645 | Mon May 24, 2021 9:14 pm by DanT56 |
Where to get a clutch in OZ? k100by dallasf | 6 | 863 | Fri May 21, 2021 10:49 am by JiiPee63 |
Remove swingarm and gearbox together?by 73MOH | 23 | 1544 | Fri May 21, 2021 9:49 am by 73MOH |
Installing Valve Cover Gasketby jnclem | 16 | 1624 | Wed May 19, 2021 11:47 am by JiiPee63 |
K100 Drivetrain Lookoverby DevilDesignFirst time with EFI | 10 | 913 | Tue May 18, 2021 12:33 pm by Point-Seven-five |
Tranny & rear end lube seepageby jjefferies | 2 | 735 | Sat May 15, 2021 2:56 am by MartinW |
Inlet Manifold Leakby jjefferiesK75 Inlet Manifold leak | 12 | 1458 | Fri May 14, 2021 10:40 pm by jjefferies |
After market Temperature sensor leakby PajoAfter market Temperature sensor leak | 5 | 884 | Sat May 08, 2021 12:29 am by Dai |
Oil additive for valve guidesby RocknBlues | 8 | 1678 | Thu May 06, 2021 7:33 pm by gorio |
Waterpump gear rubbingby P.Kopperud | 1 | 1085 | Tue May 04, 2021 6:27 pm by Suzi Q |
Ebay Aluminum Radiator Thoughtsby dwnhillskater | 24 | 2408 | Fri Apr 23, 2021 6:07 am by Wiz |
['93 K75] Correct tensioning for new Clutch cable / front-end swap?by roach374 | 3 | 639 | Thu Apr 22, 2021 5:28 pm by roach374 |
K1100 output shaft end floatby 88 | 2 | 756 | Sun Apr 18, 2021 12:07 pm by 88 |
1994 1100 LT - Final Driveby K-dawgFinal Drive Maintenance Splines/ lubricant and Oil | 15 | 936 | Sat Apr 17, 2021 4:34 am by K-dawg |
An issue with a camshaft bearing clampby JiiPee63 | 14 | 1946 | Wed Apr 14, 2021 10:13 am by 92KK 84WW Olaf |
K75 FLooding, Is it Possibleby jjefferiesK75 Engine not starting from cooldown | 5 | 837 | Mon Apr 12, 2021 8:44 pm by MartinW |
Topics [50]
- No new posts
- New posts
- New posts [ Popular ]
- New posts [ Locked ]
