Topics [0]
Automatic cancelby Rockman | 13 | 1460 | Wed Sep 02, 2015 6:28 am by robmack |
Fuel Gaugeby Howard64180 | 5 | 3037 | Sun Aug 30, 2015 9:04 am by Howard64180 |
No Brake light K100 1985by MumblesLED brake light doesn't work | 31 | 5158 | Thu Aug 27, 2015 11:13 am by Mumbles |
after market warning lightsby peely1k100 rs 1985 cant get the neutral light or oil light to work?? | 2 | 1375 | Thu Aug 27, 2015 8:10 am by Motorbike Mike |
16.7v from the Alternatorby rapt | 6 | 1620 | Mon Aug 17, 2015 9:22 am by Dai |
Another Hall sensor question...by Dai | 9 | 1724 | Fri Aug 14, 2015 9:16 am by Dai |
Fried electricsby KyleMBFried electrics | 3 | 1418 | Fri Aug 14, 2015 5:57 am by Dai |
Fan Sensor/Relay testby bkhK75 | 6 | 2109 | Thu Aug 13, 2015 7:37 am by Dai |
Charging Woesby brickrider | 14 | 1667 | Sun Aug 09, 2015 11:51 pm by Point-Seven-five |
Fuel lights randomly workingby TheJoker1984 k100 fuel lights randomly work | 3 | 1425 | Sat Aug 08, 2015 7:55 pm by Stan |
Charge lamp glowsby Puccini | 5 | 1447 | Sat Aug 08, 2015 10:38 am by Puccini |
Bmw 2 pin (Bullet) connectionby TheJokerAfter a BMW electrical component. | 4 | 1586 | Fri Jul 31, 2015 9:12 pm by JR_K100RS |
Weird Electrical Problem (Now Working)by TheJokerAs of title (headlight, indicator & starter weirdness) | 32 | 2046 | Thu Jul 30, 2015 10:23 am by TheJoker |
electrics playing upby Ajayshelp | 12 | 1860 | Mon Jul 27, 2015 10:35 am by sidecar paul |
1984 k100 won't start.[ 1, 2 ] by gabriel | 93 | 11719 | Sun Jul 26, 2015 7:16 am by K75cster |
Fan Relayby Howard64180 | 2 | 1455 | Fri Jul 24, 2015 6:56 pm by charlie99 |
Internal Circuit Modification for Bulb Failure Relayby two66mhzConverstaion about Intergrated Circuit Modifications allowing Relay Bypass | 20 | 2471 | Mon Jul 20, 2015 8:55 am by Holister |
Starter motor wont stop.............by andyb | 16 | 2009 | Fri Jul 17, 2015 3:41 am by charlie99 |
K100RS Motronic fuel chip remapby Motorbike Mike | 9 | 5440 | Sat Jul 11, 2015 7:31 am by Rick G |
after replacing starter motor brushes, starter only spinsby Amster | 41 | 6758 | Wed Jul 08, 2015 11:44 pm by kioolt |
Odd Electrical Gremlinby K100Sprint | 7 | 1819 | Wed Jul 08, 2015 8:52 pm by Rick G |
New tail light bulb...LEDby DeRodster | 15 | 3356 | Tue Jul 07, 2015 6:02 pm by DeRodster |
Complete electrical failure--odd experience but working now; would still like inputby KJustin | 22 | 1938 | Tue Jul 07, 2015 3:39 am by charlie99 |
Alternator light always without keys, then goes off when runningby Stickersman | 10 | 2155 | Mon Jul 06, 2015 2:59 pm by Mossy1200 |
1990 K100 RS 16V ABS MODELby marknicowire from under bike | 2 | 1373 | Sun Jul 05, 2015 12:33 pm by marknico |
Starter Motor Questionby TacKler | 2 | 1772 | Fri Jul 03, 2015 4:21 am by TacKler |
Abs unit - testing Ireland.by 88 | 3 | 1264 | Thu Jul 02, 2015 11:41 am by 88 |
ABS light on...need some advice on the basicsby Nigel T | 9 | 2590 | Sun Jun 28, 2015 6:09 am by Nigel T |
injectorsby dwosborn | 8 | 1565 | Tue Jun 23, 2015 11:19 am by Rick G |
Frustrated K100rs Owner Saga Continuesby robdiaz44 | 19 | 1828 | Thu Jun 18, 2015 10:04 pm by Holister |
Opinions on which gauges to addby K100Sprint | 26 | 3250 | Sun Jun 14, 2015 1:27 am by Mark K Boy |
The weird gets weirderby HairballNew injector o-rings cause eternal light... | 5 | 1536 | Sat Jun 13, 2015 8:30 pm by Rick G |
Here we go again ... (starting issue)by K100Sprint | 6 | 1808 | Mon Jun 08, 2015 10:05 pm by Holister |
installing additional instruments (temperature and fuel gauge) - work completedby abbocath | 37 | 11671 | Thu May 28, 2015 3:54 am by Stickersman |
K75RT will not startby George R | 2 | 1397 | Wed May 27, 2015 10:22 pm by Holister |
Hall effect sensors - cable lengthby Dai | 6 | 1542 | Wed May 27, 2015 12:25 pm by Dai |
Fuse blowsby Donmystic1Naked K100 instrument lights fuse blows | 4 | 1544 | Tue May 26, 2015 4:54 pm by Donmystic1 |
hazard lamp and BMUby Noeloakeshazard lamp staying on | 16 | 1641 | Mon May 25, 2015 11:10 am by Rick G |
battery replacementby cracked canoe | 10 | 2367 | Sat May 23, 2015 6:03 am by Holister |
Speedo/Odometer brass screw holes stripedby cliverocky | 0 | 1262 | Thu May 21, 2015 6:10 am by cliverocky |
Rear brake light switch - a senior momentby C_Mick | 27 | 3131 | Tue May 19, 2015 5:21 pm by Inge K. |
Green button crapped itselfby td5 | 6 | 1413 | Tue May 19, 2015 9:26 am by td5 |
temperature relayby smoll1 | 9 | 1898 | Tue May 19, 2015 5:52 am by charlie99 |
Fuel pump testing[ 1, 2, 3, 4 ] by FissionMailed | 172 | 9482 | Mon May 18, 2015 12:18 am by Holister |
fitting a taller Motobattby Holister | 5 | 1598 | Fri May 15, 2015 9:53 am by 88 |
Voltage regulator source other than onlineby 3DdesignsK75S | 6 | 1549 | Thu May 14, 2015 12:27 pm by 3DdesignsK75S |
Wire plug connections Karambaby gladstone sa old fart | 3 | 1464 | Wed May 13, 2015 9:08 pm by gladstone sa old fart |
Heated gripsby martin_hjelseth | 5 | 1907 | Wed May 13, 2015 4:50 pm by Born Again Eccentric |
Electrical trouble mounting aftermarket digital speedoby Adil86Neutral indicator light, gear indicator, RPM | 25 | 12296 | Wed May 13, 2015 4:41 pm by Motorbike Mike |
New battery, no power.by wheels149 | 17 | 1985 | Tue May 12, 2015 6:10 am by wheels149 |
Topics [50]
- No new posts
- New posts
- New posts [ Popular ]
- New posts [ Locked ]
