Topics [0]
Which Eastern beaver headlight kitby MT350Explorer | 10 | 2339 | Fri Feb 22, 2013 1:51 am by MT350Explorer |
Koso Speedo Fitmentby Keg | 3 | 1758 | Wed Feb 20, 2013 1:31 am by Keg |
Bosh Electronic Ignition unitby 88 | 16 | 2131 | Sat Feb 16, 2013 3:30 pm by K-BIKE |
Acewell 2853 Installby Cafe-KFuel Pump | 11 | 2452 | Fri Feb 15, 2013 10:54 pm by Cafe-K |
93 K1100 ABS Wiringby Cafe-KRemoving ABS | 0 | 1497 | Tue Feb 12, 2013 7:31 pm by Cafe-K |
[solved]powering accessories k100?by TRIceberg | 4 | 1623 | Mon Feb 11, 2013 10:59 am by TRIceberg |
K100 Ser#0000790by bravoalpha99A little bit sick | 7 | 1799 | Sat Feb 09, 2013 9:13 pm by K-BIKE |
Speedo fixedby Ghost who rides3rd time lucky | 10 | 2080 | Fri Feb 08, 2013 3:45 pm by K-BIKE |
Motronic Harness Wornby Cafe-K | 6 | 1686 | Fri Feb 08, 2013 3:42 pm by K-BIKE |
BMW K1100LT Fusesby Cafe-KFuse Layout | 10 | 9888 | Fri Feb 08, 2013 3:23 pm by K-BIKE |
Charging flat battery - K1100ltby DeRodster | 16 | 3325 | Sat Jan 26, 2013 3:49 pm by K-BIKE |
LED instrument lightsby Guest | 7 | 2404 | Fri Jan 25, 2013 3:19 am by Adiwan Djohanli |
Indicator, leds[ 1, 2, 3 ] by Stan | 117 | 7548 | Thu Jan 17, 2013 7:16 pm by Tenox |
charging socketby ali2908 | 13 | 4538 | Fri Jan 11, 2013 5:42 pm by ali2908 |
Lost keyby JimK | 12 | 4492 | Fri Jan 11, 2013 3:27 am by Ajays |
Running W/O instrument clusterby motojava | 7 | 1750 | Thu Jan 10, 2013 5:18 pm by motojava |
!988 K75S headlight switch dismantled picture.by BooG | 9 | 2967 | Sun Jan 06, 2013 4:19 pm by BooG |
Switch dismantleby BooG | 0 | 1197 | Tue Jan 01, 2013 4:42 pm by BooG |
Hall Sensor testing questionby twincarbIs it possible to use an osciliscope to check the crank speed.... | 0 | 1336 | Sat Dec 29, 2012 11:17 am by twincarb |
Standard 16v Chipby electric_monk | 2 | 1470 | Sat Dec 22, 2012 1:51 pm by electric_monk |
1985 K100rs Misfire @ idle & cyl "drop out" SOLVEDby ibjmanThanks to all who contributed | 10 | 2600 | Fri Dec 21, 2012 11:02 pm by charlie99 |
update K-Wiki - Wiring diagram Lunchboxby zonenfeile | 7 | 1884 | Thu Dec 20, 2012 8:12 pm by Inge K. |
Fuel pump not workingby Westminster | 20 | 2434 | Thu Dec 20, 2012 4:36 pm by Halo |
starter questionby thegreatfordstarter - new battery- runs about 8 seconds then acts like dead battery | 3 | 1434 | Fri Dec 14, 2012 10:54 pm by thegreatford |
Heated Gripsby gmcqSmoke | 26 | 3437 | Fri Dec 14, 2012 7:39 pm by Rick G |
Starter Issue, ugh wiring!by Rabidchiwawa007 | 32 | 7561 | Fri Dec 14, 2012 7:35 pm by Rick G |
radio on the bikeby Crazy Frog | 8 | 3378 | Sun Dec 09, 2012 5:13 am by charlie99 |
Ungo boxby ARTCOLLINSJRAlarm removal | 1 | 1286 | Tue Dec 04, 2012 11:47 pm by Two Wheels Better |
Aussie 85 K100RT late or early model wiring diagram?by delToro | 6 | 2416 | Tue Dec 04, 2012 7:43 pm by JimK |
No horn. No right indicator (Resolved)by rosskko | 5 | 1538 | Sun Dec 02, 2012 5:22 am by klompy the grey brick |
Instrument strikeby Standead instruments | 3 | 1344 | Fri Nov 30, 2012 3:27 am by charlie99 |
A really weird oneby eastern_phoenixStarting | 9 | 1628 | Thu Nov 29, 2012 7:49 pm by Inge K. |
What about the welders?by Comberjohn | 17 | 2272 | Thu Nov 29, 2012 4:44 pm by twincarb |
can anyone tell me what should be the resistance of the H.T coils on our bikes?by roys | 7 | 2041 | Wed Nov 28, 2012 7:54 pm by Crazy Frog |
Eletrickery problems.by Guest | 27 | 2074 | Wed Nov 28, 2012 5:20 pm by Guest |
Checking the Hi /Low beam switchby Crazy Frog | 30 | 3184 | Sun Nov 25, 2012 6:35 am by klompy the grey brick |
Electrical socket fuseby electric_monk | 2 | 1276 | Sat Nov 24, 2012 6:18 pm by electric_monk |
Code 7 - ABS 1.5by George R | 10 | 2023 | Fri Nov 23, 2012 11:04 pm by K-BIKE |
Spark Problems[ 1, 2 ] by RT | 65 | 4010 | Wed Nov 21, 2012 10:10 pm by RT |
Electrical faultby JM712Fan Comes on with temp Light, engine cool, bike does not start, but eventually does. | 5 | 1358 | Wed Nov 21, 2012 6:05 pm by JM712 |
A heated issue....by twincarbFitting heated grips | 11 | 1545 | Wed Nov 21, 2012 4:40 pm by sidecar paul |
ABS1 v2.5 failure, repair and consequensesby GerryPSorry it's a long story but I think its worthwhile... | 4 | 1708 | Mon Nov 19, 2012 5:56 pm by GerryP |
Odd electrical faultby kfilipowK won't start | 26 | 2220 | Tue Nov 13, 2012 4:08 am by Inge K. |
Hazard switchby Banditrob | 5 | 2101 | Sun Nov 11, 2012 6:34 pm by Banditrob |
ABS woesby MT350Explorer | 17 | 1823 | Sat Nov 10, 2012 4:51 pm by sidecar paul |
Hot fuel pumpby Adiwan Djohanli | 29 | 3563 | Thu Nov 08, 2012 5:04 am by K75cster |
Battery healthby MT350Explorer | 8 | 1508 | Mon Nov 05, 2012 3:48 pm by MT350Explorer |
Indicator Gremlinby UK_Kev | 9 | 1877 | Sun Nov 04, 2012 4:42 pm by GerryP |
Any idea where this cable and connectors go?by ianburgess | 21 | 3038 | Sat Nov 03, 2012 3:34 pm by Inge K. |
Motometer corrosion problemby 1webster1I am trying to clean the contacts on the gear shift indicator... | 8 | 1807 | Fri Nov 02, 2012 5:07 pm by K-BIKE |
Topics [50]
- No new posts
- New posts
- New posts [ Popular ]
- New posts [ Locked ]
