Topics [0]
Bevel Box Uni Joint Removalby Guest | 3 | 1286 | Sat Oct 05, 2013 11:40 pm by Guest |
Help with ht lead I.Dby colinijohnson | 3 | 1314 | Sat Oct 05, 2013 9:32 pm by the.postman |
Wont start..................by MXI | 9 | 2040 | Sun Sep 29, 2013 10:33 pm by Rabidchiwawa007 |
1992 k100rs 16v water/oil pump sealsby Rabidchiwawa007 | 2 | 1523 | Sun Sep 29, 2013 6:52 pm by Rabidchiwawa007 |
Timing / Cam chain re-vampby Rabidchiwawa007 | 4 | 1498 | Sun Sep 29, 2013 4:02 pm by Rabidchiwawa007 |
Silver or Black?by Brynogwy | 5 | 1409 | Sun Sep 29, 2013 5:08 am by Brynogwy |
Valve cover Mystery springby RTMissing | 1 | 1316 | Sat Sep 28, 2013 9:09 pm by Rick G |
K100RS 16v valve adjustmentby mr grumpy | 4 | 1905 | Thu Sep 26, 2013 7:55 pm by mike d |
Engine Maintenanceby gsmithDamaged Oil Cap/Pan Screws | 4 | 1172 | Tue Sep 24, 2013 8:41 am by Rick G |
Help please - sputtering.by jr | 3 | 1086 | Thu Sep 19, 2013 10:31 pm by jr |
Gear shiftsby sudhirjin | 4 | 1306 | Wed Sep 18, 2013 12:03 am by K75cster |
Clutch inspection?by kingtorbenI vave a K100 4v, 1990. I wonder if I can inspect the clutch-disc, without unmounting the whole gearbox | 2 | 1393 | Tue Sep 17, 2013 12:58 pm by nino |
85 or "European" camsby Dewey V | 14 | 3799 | Fri Sep 13, 2013 6:48 am by Ajays |
new boltsby nino | 2 | 1338 | Wed Sep 11, 2013 9:19 pm by robmack |
Fuel Cap Orientation 1987 K100RS/RTby Shep | 7 | 1323 | Wed Sep 11, 2013 7:57 pm by Shep |
air/fuel mixtureby k-rider | 15 | 2791 | Tue Sep 10, 2013 12:32 pm by k-rider |
K100 dies after hot fast runby EdmateStarting to think my k100 is unreliable. | 11 | 2262 | Tue Sep 10, 2013 7:31 am by Edmate |
K75 silencer gasketby JGT | 2 | 1331 | Mon Sep 09, 2013 9:08 pm by Rick G |
The air hose from the front of the air box to the back of the TBsby Rabidchiwawa007 | 4 | 1618 | Mon Sep 09, 2013 5:19 pm by Two Wheels Better |
K100 exhaust system compatibilityby Rabidchiwawa007 | 14 | 5455 | Mon Sep 09, 2013 11:40 am by Guest |
Fuel Injector adjustment question.by PucciniAdjustment parameters | 10 | 2006 | Sun Sep 08, 2013 5:42 am by charlie99 |
Newbie Coolant Change Questionby klamityboy | 19 | 5909 | Sat Sep 07, 2013 9:00 am by Rick G |
Oil filter wrenchby OZhoppo | 3 | 2177 | Sat Sep 07, 2013 8:47 am by blaKey |
Cooling System Flush recommendationsby klamityboy | 4 | 1645 | Sat Sep 07, 2013 5:22 am by charlie99 |
K1100 engine in K100 frame and vice versaby krambo | 10 | 4785 | Wed Sep 04, 2013 11:41 am by alldigits |
K100 Turboby rosskkoCourtesy of Motorworks | 6 | 1880 | Mon Sep 02, 2013 11:39 am by MikeP |
Crush Washer sizing questionby klamityboy | 1 | 1214 | Thu Aug 29, 2013 10:07 pm by Rick G |
Fuel Injector reconditioning recommendations in Canadaby klamityboy | 5 | 1430 | Thu Aug 29, 2013 6:17 pm by welshlamb |
Ignition works, there's sparks, fuel, but no start.[ 1, 2 ] by TSBT | 63 | 7737 | Sun Aug 25, 2013 12:37 pm by TSBT |
"Choke" lever inactive.by RT | 7 | 1557 | Fri Aug 23, 2013 11:54 pm by RT |
Measurement of fasteners/boltsby jjefferies | 3 | 1373 | Fri Aug 23, 2013 11:09 pm by robmack |
K75S Clutch Rattleby Tom G | 2 | 1457 | Fri Aug 23, 2013 2:28 am by Tom G |
92 k75 needs some expertise on an issueby MikeisonTV | 8 | 1286 | Wed Aug 21, 2013 3:01 pm by the.postman |
K75 Restoration Clutch Issueby jjefferiesWhether or not to | 22 | 2322 | Tue Aug 20, 2013 9:13 pm by jjefferies |
Cafe K1100 Back to Life!!by Cafe-KEngine output shaft seal replacement/transmission input shaft replacement | 1 | 1298 | Mon Aug 19, 2013 3:02 am by charlie99 |
Why one-time use bolts on clutch?by jjefferies | 13 | 2652 | Sat Aug 17, 2013 8:07 am by Guest |
Did ya Know[ 1, 2 ] by Dennis | 70 | 5691 | Wed Aug 14, 2013 6:38 pm by Guest |
12 rivet output shaft .. When?by Guest | 19 | 3655 | Wed Aug 14, 2013 12:22 pm by ibjman |
Service after 5 years no runningby hks300 | 41 | 2804 | Fri Aug 09, 2013 8:43 pm by Rick G |
What is the best way to clean and refurbish the engine, trans and final drive aluminum parts, to look originalby wildwestrider | 2 | 1744 | Fri Aug 09, 2013 2:35 am by Ghost who rides |
Clutch pushrod gaiter, loose fit on armby jose_swervo | 4 | 1423 | Thu Aug 08, 2013 8:46 pm by jose_swervo |
turbo k100by Ed | 12 | 8080 | Thu Aug 08, 2013 9:35 am by JimK |
Camshaft Bearingblock - worn thread for valve coverby zonenfeile | 6 | 1989 | Thu Aug 08, 2013 3:37 am by zonenfeile |
Trick for eliminating handlebar vibrationby browe58 | 32 | 9516 | Wed Aug 07, 2013 6:09 am by 92KK 84WW Olaf |
What is this washer?by ltisz | 15 | 1893 | Tue Aug 06, 2013 12:37 am by ltisz |
Throttle Bodies.by Guest | 12 | 1922 | Mon Aug 05, 2013 5:15 am by Guest |
Catalyst is out!by metalist2006I need a manual. | 4 | 1292 | Mon Aug 05, 2013 3:51 am by MikeP |
Any ideas for a drill guide to drill oil pressure switch hole?by Jim Miller | 15 | 1947 | Sun Aug 04, 2013 2:39 pm by ibjman |
More water pump woesby bolts | 15 | 2123 | Sat Aug 03, 2013 3:09 am by MT350Explorer |
Valve adjustment party Sydneyby klompy the grey brick | 46 | 2946 | Fri Aug 02, 2013 5:24 am by charlie99 |
Topics [50]
- No new posts
- New posts
- New posts [ Popular ]
- New posts [ Locked ]
