Topics [0]
Leaky intakeby James | 2 | 1476 | Sun Mar 18, 2012 7:38 pm by James |
a couple of problems in new season...by pajonk | 5 | 1346 | Sat Mar 17, 2012 4:54 am by K-BIKE |
Gasket seal between FD/swingarm or between tranny/bell housingby bobgass | 8 | 1898 | Thu Mar 15, 2012 11:17 pm by bobgass |
Pressure in crack case??by ReneZ | 1 | 1411 | Thu Mar 15, 2012 8:46 pm by Rick G |
Timing Chainby twincarbHow do we know when the timing chain is in need of replacement | 7 | 1999 | Thu Mar 15, 2012 5:44 pm by yankeeone |
Shredded Clutch Plate splinesby Lazyboy | 7 | 3268 | Tue Mar 13, 2012 9:05 pm by Rick G |
Is this the correct 'C' spanner fro the 16 valve?by MT350Explorer | 6 | 2215 | Tue Mar 13, 2012 5:51 pm by japuentes |
final drive questionby 2slow | 3 | 1412 | Mon Mar 12, 2012 10:20 pm by Inge K. |
Fuel pump replacedby Moto SmithPreventative maintenance, well not quite. | 1 | 1435 | Mon Mar 12, 2012 11:29 am by charlie99 |
body throttle butterflyby DomingoRemoving the body throttle butterfly | 15 | 1943 | Sat Mar 10, 2012 4:02 pm by K-BIKE |
Serious Oil Leak (SOLVED)by fearlesspk1992 K100RS | 10 | 1822 | Fri Mar 09, 2012 6:42 am by charlie99 |
K100 RT bevel boxby scorpiobikerLooking to improve economy | 4 | 1656 | Mon Mar 05, 2012 8:56 pm by K75cster |
tranny rebuildby DRxBMWgearbox help | 3 | 1677 | Sun Mar 04, 2012 8:04 pm by Rick G |
Replacement Rear Drive Unitby CanberraDave | 4 | 1795 | Wed Feb 29, 2012 6:37 pm by col |
Exhaust - Help with Identification please.by 88 | 15 | 1842 | Wed Feb 29, 2012 6:45 am by sidecar paul |
What oils to useby stoofy | 9 | 2132 | Tue Feb 28, 2012 9:45 pm by K75cster |
Oh deary meby hitmanhI've lost my splineyness | 4 | 1551 | Mon Feb 27, 2012 6:38 pm by hitmanh |
Air leak in the first butterfly...by pajonk | 15 | 2213 | Sat Feb 25, 2012 5:43 pm by RT |
Noise in gearbox/clutchby caferacer62 | 14 | 3763 | Thu Feb 23, 2012 6:03 am by Inge K. |
Breather hoseby Brickee | 2 | 1615 | Tue Feb 21, 2012 7:24 pm by Brickee |
Gearbox oil gone and replaced with air pressure.by 88 | 24 | 3877 | Mon Feb 20, 2012 7:56 pm by Inge K. |
92 K100RS won't start[ 1, 2 ] by krome | 65 | 5165 | Thu Feb 16, 2012 2:41 am by charlie99 |
Spline lubrication service intervalby jonnyqq | 4 | 3594 | Wed Feb 15, 2012 4:52 pm by blaKey |
Whine after engine turned offby Moto Smith | 28 | 2279 | Tue Feb 14, 2012 5:29 pm by Moto Smith |
General engine tune-up. What first?by MT350Explorer | 5 | 2421 | Sun Feb 12, 2012 3:04 am by MT350Explorer |
Auxiliary output shaft bearingby Brickee | 6 | 2515 | Fri Feb 10, 2012 7:29 am by Brickee |
Interesting overheat situation, looking for helpby FreebasserSF | 8 | 1761 | Thu Feb 09, 2012 7:56 pm by Tom G |
Oil seepageby Puccini | 21 | 1717 | Thu Feb 09, 2012 6:35 am by charlie99 |
Alignment of drive shaft U-jointsby bjarnek100 | 4 | 3464 | Wed Feb 08, 2012 1:58 pm by robmack |
That little drop of oil under the engineby FreebasserSF | 7 | 1706 | Mon Feb 06, 2012 6:45 am by BIG D |
A Trap for the Unwaryby Rick G | 4 | 1443 | Wed Feb 01, 2012 8:32 am by beanoldboy |
Harmonic vibration at 3,500 rpm ??[ 1, 2 ] by Moto Smith | 51 | 3746 | Wed Jan 25, 2012 11:47 pm by K75cster |
Moly lubricantsby Oldgoat | 6 | 1726 | Tue Jan 24, 2012 4:27 am by K-BIKE |
Anti-freeze - ratio and replacementby Moto Smith | 5 | 2796 | Sun Jan 15, 2012 3:10 am by Agerbundsen |
The four manifold stacksby Domingo | 2 | 1369 | Sat Jan 14, 2012 4:25 pm by charlie99 |
Air filter fitmentby Moto Smith | 14 | 1610 | Sat Jan 14, 2012 6:02 am by Rick G |
Fuel Filter - aftermarket part #??by Moto Smith | 7 | 2965 | Fri Jan 13, 2012 11:50 am by Moto Smith |
Air flow meter on a 16Vby bjarnek100 | 2 | 1698 | Wed Jan 11, 2012 7:17 pm by Inge K. |
'U' Shaped hole in oil pump face - engine sideby Moto Smith | 2 | 1698 | Sun Jan 08, 2012 12:53 pm by Moto Smith |
k100 running problemby johnhilditch | 10 | 3711 | Sun Jan 08, 2012 6:25 am by charlie99 |
Clutch Splinesby JonnyE | 5 | 1854 | Sat Jan 07, 2012 4:54 am by ReneZ |
Con rod damageby zonenfeile | 6 | 1535 | Fri Jan 06, 2012 1:56 pm by ReneZ |
K 100 8v TPS adjustby Domingo | 15 | 3656 | Thu Jan 05, 2012 6:15 pm by Domingo |
Alternate coolantby bobgass | 21 | 2512 | Thu Jan 05, 2012 6:09 pm by RT |
shifting into 5th gearby joem | 4 | 1963 | Wed Jan 04, 2012 5:45 pm by joem |
85 k100rs goes too fast?[ 1, 2 ] by whhoon | 51 | 3954 | Mon Jan 02, 2012 11:24 am by CommanderKewl |
Slip-ring seal for oil/water pump Part #sby Moto Smith | 1 | 1972 | Sun Jan 01, 2012 4:02 pm by K-BIKE |
Seen this? Weld-on repair for 16 and 20 teeth splinesby blaKey | 8 | 2744 | Fri Dec 30, 2011 5:58 am by hot_seat |
engine oil in water reservoirby charlie99 | 28 | 4231 | Thu Dec 29, 2011 8:06 am by Dennis |
Valve Pucks for 5.95 each plus $6. S/H - FYIby Moto Smith | 0 | 1713 | Tue Dec 27, 2011 5:05 pm by Moto Smith |
Topics [50]
- No new posts
- New posts
- New posts [ Popular ]
- New posts [ Locked ]
