Topics [0]
Hall Sensors State sideby Oldgoat | 7 | 2668 | Thu Sep 13, 2012 6:58 am by blaKey |
Clutch adjustmentby hitmanh | 4 | 1684 | Wed Sep 12, 2012 10:23 am by hitmanh |
Spline Lubeby JonnyEHaving finally pulled everything apart to perform a spline lube, I'm not sure if the splines on the engine output shaft need lubing also, as part of general maintenance... | 5 | 2352 | Tue Sep 11, 2012 3:56 am by JonnyE |
why is it so hot?by Farmmedic | 4 | 1441 | Fri Sep 07, 2012 10:02 pm by Rick G |
Aftermarket Exhaust + System Cases = Epic Fail!by zaubertuba | 13 | 2157 | Thu Sep 06, 2012 4:52 pm by Crazy Frog |
fuel hose blew upby VPutin | 17 | 2116 | Thu Sep 06, 2012 4:22 pm by sidecar paul |
Woodepecker at 3000 RPMby 88 | 29 | 2112 | Mon Sep 03, 2012 7:20 am by rosskko |
petrol tankby lessoremovel | 16 | 2115 | Sat Sep 01, 2012 12:13 pm by BIG D |
Misfire on over-runby Paul Friday | 27 | 5619 | Tue Aug 28, 2012 10:11 am by Rick G |
Gearbox leaking at gear leverby rosskko | 1 | 1802 | Mon Aug 27, 2012 4:45 am by Inge K. |
Stripped drain plug in final drive case.by Guest | 20 | 2322 | Mon Aug 27, 2012 4:43 am by Stan |
K100 throttle body air filters/K$Nby rwiley111converting to K$N cone filters | 10 | 8973 | Sun Aug 26, 2012 9:33 am by Motorandy123 |
Transmission weight?by Oldgoat | 17 | 2066 | Thu Aug 23, 2012 2:52 am by andyb |
Bike wont start coldby Wombat | 10 | 2029 | Tue Aug 21, 2012 7:07 am by charlie99 |
Can Throttle Bodies be reconditioned??by andyb | 4 | 1588 | Mon Aug 20, 2012 2:16 am by Ned |
Fuel smell in clothes after riding a bike.by joao.c130Problem solving! | 1 | 1662 | Sat Aug 18, 2012 7:43 pm by RT |
Engine not firingby twincarbcarry on from the electrics forum due to compression problem | 25 | 2338 | Fri Aug 17, 2012 4:50 pm by twincarb |
ALTERNATE K100RT 1984 VALVE SHIMSby Lazyboy | 3 | 2173 | Thu Aug 16, 2012 9:26 am by sven k100 |
Engine, left side ticking noise.by Rabidchiwawa007Lifter issue? | 7 | 3554 | Tue Aug 14, 2012 2:16 am by Rick G |
Engine block wearby shay | 25 | 2734 | Mon Aug 13, 2012 12:59 am by Ghost who rides |
Stuck speedo driveby ali2908 | 5 | 1721 | Sun Aug 12, 2012 2:34 am by Two Wheels Better |
Sump plug gasket?by dalderton | 6 | 2037 | Sat Aug 11, 2012 12:29 am by dalderton |
Name/Part numbers for two red O-rings next to output shaftby paul.dickson_VA | 15 | 1993 | Wed Aug 08, 2012 11:11 am by Inge K. |
k100 stumble at 1800rpmby yankeeone | 17 | 1764 | Sun Aug 05, 2012 4:58 am by charlie99 |
Output shaft removalby paul.dickson_VAPossible problems while removing shaft | 3 | 2143 | Sat Aug 04, 2012 12:48 pm by paul.dickson_VA |
bevelbox input shaft splinesby hitmanh | 7 | 3126 | Thu Aug 02, 2012 7:48 am by hitmanh |
Re-built water pumpby captaink | 37 | 3034 | Mon Jul 30, 2012 11:45 am by sven k100 |
Vacuum leak at T/B'sby caferacer62 | 6 | 1826 | Mon Jul 30, 2012 10:21 am by Two Wheels Better |
fuel tank repairby ridefarholes repaired with permatex epoxy | 5 | 1581 | Sun Jul 29, 2012 7:51 pm by ridefar |
Corroded exhaust headersby giles4060 | 1 | 1572 | Sun Jul 29, 2012 7:32 pm by twincarb |
K100RS Gear selector pedal does not return to midpoint.by fretherne | 4 | 6883 | Sun Jul 29, 2012 7:02 am by fretherne |
Help please. On the road and overheated.by docious | 9 | 1578 | Sat Jul 28, 2012 6:09 pm by K-BIKE |
Gear lever: am I screwed?by ali2908 | 16 | 2043 | Thu Jul 26, 2012 4:33 pm by ali2908 |
Timing Chain Tensionerby madmartNeed to change the timing chain tensioner on 1984 K100Rs | 1 | 1628 | Thu Jul 26, 2012 2:50 pm by nino |
K100RS throttle cable bluesby brickriderHow's it replaced? | 8 | 1783 | Wed Jul 25, 2012 12:49 pm by charlie99 |
Comparo: K75/K100(8V) pistonsby Two Wheels Better | 17 | 5287 | Tue Jul 24, 2012 8:21 am by Two Wheels Better |
What's wrong with my shaft drive?by giles4060 | 49 | 8821 | Sun Jul 22, 2012 8:35 am by 88 |
Rough runningby otto59Rough running engine | 7 | 1700 | Sat Jul 21, 2012 11:36 pm by RT |
k100 86 drive shaft universal vibrateby yankeeone | 1 | 1616 | Thu Jul 19, 2012 11:02 pm by Rick G |
An oil bath for the final drive splines?[ 1, 2 ] by sidecar paul | 63 | 7299 | Mon Jul 16, 2012 10:44 am by Rick G |
it worked !by ken connerfuel filter repair | 2 | 1549 | Mon Jul 16, 2012 7:20 am by K75cster |
Brakes bled but still spongy feel???by KJB | 13 | 3238 | Sun Jul 15, 2012 9:24 am by Two Wheels Better |
Rear Main Seal Replacementby docious | 8 | 4588 | Fri Jul 13, 2012 7:31 pm by docious |
Possible valve problem?by paul.dickson_VAWet oil in the first header pipe | 4 | 1528 | Fri Jul 13, 2012 4:51 am by ReneZ |
mayday - maydayby ken connerdamaged fuel pump | 6 | 1500 | Wed Jul 11, 2012 1:18 am by Two Wheels Better |
Engine Knockingby petrichbEngine Knocking | 3 | 1583 | Tue Jul 10, 2012 9:01 am by 92KK 84WW Olaf |
output shaft replace 86 k100 ( motor out of bike)by yankeeone | 9 | 1963 | Mon Jul 09, 2012 9:27 am by yankeeone |
Good Vibrations....by Lucky Louis it normal | 3 | 1293 | Mon Jul 09, 2012 4:21 am by JGT |
Vibrationby Avenger GT | 9 | 1855 | Sun Jul 08, 2012 8:00 pm by 92KK 84WW Olaf |
Engine Rebuild on Utubeby twincarb | 3 | 1782 | Sun Jul 08, 2012 5:25 pm by sidecar paul |
Topics [50]
- No new posts
- New posts
- New posts [ Popular ]
- New posts [ Locked ]
