Topics [0]
Engine Rebuild on Utubeby twincarb | 3 | 1788 | Sun Jul 08, 2012 5:25 pm by sidecar paul |
Replacing leaking engine sealsby paul.dickson_VALooking for best approach (engine in bike or removed) | 3 | 1450 | Thu Jul 05, 2012 6:43 am by charlie99 |
Tip of the day....by Crazy FrogSimple solution to check the fuel pressure regulator | 0 | 1271 | Mon Jul 02, 2012 4:03 pm by Crazy Frog |
copper gaskets k100 exhaust flangeby yankeeone | 3 | 1961 | Sun Jul 01, 2012 10:39 pm by yankeeone |
Final Drive Unitby smoll1Final Drive Bearing Fix | 4 | 1674 | Sun Jul 01, 2012 1:48 pm by smoll1 |
Needle bearing removalby BooG | 9 | 1749 | Sun Jul 01, 2012 10:43 am by Rick G |
Gearbox and pressure plateby gabriel1984 k100 | 19 | 7941 | Fri Jun 29, 2012 8:02 pm by twincarb |
Rattlng noise from gearbox area on 1985 K100RTby STEVE1959 | 7 | 3141 | Fri Jun 29, 2012 3:52 pm by ReneZ |
Rubber bootby BooG | 2 | 1478 | Thu Jun 28, 2012 5:28 pm by BooG |
Ratchet noise when driving off?by SuicidalbadgerAfter starting and selecting 1st, as I engage clutch I get a ratcheting noise from the gearbox/drive | 8 | 1594 | Thu Jun 28, 2012 3:56 am by charlie99 |
shifter shaft screw tightening.by scout18Transimiison pulling on an 1985 k100RS | 6 | 1547 | Thu Jun 28, 2012 3:52 am by scout18 |
RS dumping fuel all over the place...by Kingsly | 12 | 5026 | Tue Jun 26, 2012 11:14 pm by japuentes |
Rear Main Seal removal - K100RSby TSBT | 14 | 10387 | Tue Jun 26, 2012 12:42 am by wez1 |
Leaky alternatorby otto59 | 17 | 2796 | Mon Jun 25, 2012 3:16 pm by jeffeaby |
New oil leakby captaink | 5 | 1757 | Mon Jun 25, 2012 5:59 am by captaink |
K100RS Clutch Plate Removal Noobie Questionsby TSBT | 18 | 5297 | Fri Jun 22, 2012 8:12 am by Rick G |
1985 K100 RS replacement exhaust not sameby ali2908 | 8 | 2146 | Fri Jun 22, 2012 7:14 am by ali2908 |
Clutch push rodby captaink | 2 | 1570 | Fri Jun 22, 2012 3:58 am by captaink |
redex worth a go?by artie86 | 13 | 2052 | Thu Jun 21, 2012 6:48 pm by twincarb |
Emulsified final drive oilby mr grumpy | 9 | 1674 | Tue Jun 19, 2012 8:25 pm by Two Wheels Better |
2004 k1200 motorby yankeeone | 2 | 1560 | Mon Jun 18, 2012 11:06 pm by yankeeone |
75w90 vs 75w140 / dino vs synthetic gear oil for '91 k100rs 4vby browe58 | 10 | 4574 | Fri Jun 15, 2012 4:31 am by blaKey |
Transmission oil gradesby mr grumpy | 1 | 1838 | Thu Jun 14, 2012 7:41 pm by Two Wheels Better |
easy & affordable way to seal oil & vacuum leaksby browe58 | 1 | 1711 | Wed Jun 13, 2012 9:12 pm by Rick G |
what is the correct procedure for synching throttle bodies on '91 k100rs 4v???by browe58 | 6 | 2993 | Mon Jun 11, 2012 4:06 pm by mike d |
Paralever bearing replacementby mr grumpy | 4 | 2221 | Fri Jun 08, 2012 7:37 pm by Two Wheels Better |
return fuel hosesby RSMITH | 29 | 2239 | Fri Jun 08, 2012 4:59 am by charlie99 |
Gears and Top-end speedby K-Boom | 11 | 1976 | Thu Jun 07, 2012 10:29 pm by Guest |
cam cover removalby 88 | 8 | 2408 | Wed Jun 06, 2012 3:43 pm by 88 |
K100RS breather hose replaceby TSBT | 15 | 6558 | Sat Jun 02, 2012 9:24 pm by Two Wheels Better |
Some thoughts on rear splines.by sidecar paul | 18 | 2448 | Sat Jun 02, 2012 3:29 pm by japuentes |
Engine cut-out .by trikerider81engine just ground to a halt as if out of fuel . | 9 | 1831 | Wed May 30, 2012 5:49 am by rosskko |
Which adhesive for mirror pod backs?by Comberjohn | 6 | 1416 | Tue May 29, 2012 5:48 am by CanberraDave |
Cross threaded spark plugby rosskko | 17 | 2070 | Tue May 29, 2012 2:43 am by nino |
Locating engine oil leakby giles4060 | 11 | 2555 | Mon May 28, 2012 8:21 pm by Rick G |
No mercy.......... I think I'm in the shit!by ReneZstuck bolt | 22 | 2007 | Mon May 28, 2012 7:48 pm by Inge K. |
1985 K100RS fuel hose routingby brickriderWhat's the path? | 4 | 3679 | Sun May 27, 2012 2:19 pm by brickrider |
K100 RS Fuel chokingby K-Boom | 2 | 1439 | Sat May 26, 2012 4:07 am by K-Boom |
New sound coming from timing chain areaby scottiesharpe | 41 | 11183 | Fri May 25, 2012 2:16 pm by charlie99 |
is idle adjustable on '91 k100rs 4v w/ motronic???by browe58 | 25 | 5360 | Wed May 23, 2012 1:09 pm by walfish |
False neutral?by MaenadGear change problem | 19 | 3059 | Wed May 23, 2012 5:07 am by Terry Dactyl |
vibration is unbearable on newly acquired '91 k100rs..... i'm ready to dump it!!!by browe58 | 5 | 2908 | Tue May 22, 2012 6:04 pm by yankeeone |
Black plugs - diagnosis and optionsby MT350Explorer | 27 | 2307 | Sun May 20, 2012 6:21 am by ReneZ |
Timing a K100 to find the "sweet spot"by scottiesharpe | 10 | 9671 | Sat May 19, 2012 8:18 am by Rick G |
Grooved Bearingby twincarb | 5 | 1524 | Wed May 16, 2012 12:56 pm by walfish |
Bel-Ray Assembly Lube for Spline Lubeby Lazyboy | 1 | 2177 | Tue May 15, 2012 11:32 pm by K75cster |
How to swap out output shaft, engine in? [SOLVED]by club_c | 19 | 2938 | Tue May 15, 2012 6:06 am by charlie99 |
Swing Arm Bearingsby ClcinjaxGrease Cup Missing | 3 | 1904 | Sun May 13, 2012 2:17 pm by sidecar paul |
Gear Leverby JGT | 3 | 1465 | Sat May 12, 2012 10:26 pm by yankeeone |
torque value for output shaft 86 k100by yankeeone | 13 | 2009 | Wed May 09, 2012 10:20 am by yankeeone |
Topics [50]
- No new posts
- New posts
- New posts [ Popular ]
- New posts [ Locked ]
