Topics [0]
Anyone know why this is running so rough?by timz10000 | 24 | 1716 | Sat Sep 12, 2020 5:09 am by warmshed |
Transfer Shaft - Engine Replacementby tjh1985In Gear Won't Drive | 6 | 864 | Wed Sep 09, 2020 2:07 pm by tinyspuds |
K1100 RS starter problem[ 1, 2 ] by Danish bikerStarter søns but sprang clutch doesn’t turn engine | 85 | 2652 | Fri Sep 04, 2020 2:29 pm by 92KK 84WW Olaf |
URGENT PLEASE HELP CA RESIDENTS!!!by Ohnij | 23 | 1354 | Wed Aug 26, 2020 1:45 pm by Two Wheels Better |
Tight Valvesby zaubertuba | 7 | 1040 | Sat Aug 22, 2020 3:40 pm by zaubertuba |
advice needed with cam cover broken threadby audibob | 46 | 2847 | Sat Aug 22, 2020 10:44 am by Dai |
Low RPM Low Power Jerky Accelerationby OhnijUsing this post to track this issue. | 11 | 1664 | Wed Aug 19, 2020 9:02 am by Point-Seven-five |
brown oily sludge when i drained oilby ballochmank75s 1988 | 18 | 1195 | Tue Aug 18, 2020 12:44 pm by ballochman |
Radiator Vinegar Flushby Ohnij | 5 | 1156 | Wed Aug 12, 2020 8:07 pm by Point-Seven-five |
fuel gauge backlightby club_c | 12 | 1670 | Wed Aug 12, 2020 3:23 pm by Dai |
How bad did I screw up? SOLVEDby wkordo | 11 | 1123 | Tue Aug 04, 2020 8:45 pm by wkordo |
Difficulty starting 1989 K100RSby TimK100Happened overnight | 24 | 1448 | Sun Aug 02, 2020 12:50 pm by gabriel |
K100RS gearbox bearing numbersby AussieDan | 12 | 1083 | Tue Jul 28, 2020 5:43 pm by Two Wheels Better |
Another K100 running too richby Michael Sydney | 24 | 3366 | Sat Jul 25, 2020 9:47 pm by daveyson |
Starter doesn’t engageby Danish biker? | 4 | 1111 | Wed Jul 22, 2020 12:57 pm by Danish biker |
K100RS 16V Gearbox Oil Levelby ldescloiGearbox oil level and dipstick | 0 | 1200 | Sun Jul 12, 2020 10:39 pm by ldescloi |
Rattle on accelerationby mmceorangeI'm getting a mechanical rattle on mid to hard acceleration | 31 | 2209 | Sun Jul 12, 2020 9:20 pm by mmceorange |
Thrust washer behind clutch basket on k75by BooG | 4 | 940 | Thu Jul 09, 2020 8:58 am by Arlina |
1983 k100 dreaded sprag clutch adviceby wilbosprag clutch wont engage starter just spins | 22 | 1641 | Wed Jul 08, 2020 3:12 pm by MartinW |
Injection hoseby Snod Blatter | 35 | 1680 | Tue Jul 07, 2020 5:49 pm by MartinW |
Clutch arm rubber bootby billk100rtClutch arm rubber boot | 2 | 985 | Sat Jul 04, 2020 12:53 pm by gorio |
Gearbox front sealing plugby ScouserIs replacement necessary if case is heated to remove bearing race? | 4 | 826 | Thu Jul 02, 2020 6:17 pm by Scouser |
What should my rpm be at 70 mph?by mikec | 40 | 5009 | Wed Jul 01, 2020 1:41 pm by Laitch |
Chain Tensionerby Arrowkeen | 13 | 1478 | Wed Jul 01, 2020 1:59 am by Arrowkeen |
Choice of gearbox caseby ScouserGearbox case damaged; potential replacement in hand different in some respects | 2 | 887 | Sun Jun 28, 2020 4:10 am by Scouser |
K75 Low power - missing on one cylinderby MikeyDTroubleshooting to resolve a low power condition - solved and sharing for the record. | 10 | 1505 | Fri Jun 26, 2020 1:41 pm by Two Wheels Better |
Rear main seal part number K75S 1988by BooG | 2 | 892 | Fri Jun 26, 2020 1:17 pm by Two Wheels Better |
staburag NBU 30 PTM after 2000 km/1250 miles is brown powderby ooteoverheating clutch / gearbox shaft? | 9 | 1499 | Tue Jun 23, 2020 10:35 am by oote |
Snake Oil?by zaubertuba | 2 | 738 | Sun Jun 21, 2020 12:06 am by Point-Seven-five |
Low MPG (KPL for you guys across the pond)by zaubertuba | 28 | 1083 | Sat Jun 20, 2020 11:49 pm by Point-Seven-five |
Fuel Overflow cupby zaubertuba | 3 | 831 | Sat Jun 20, 2020 5:51 pm by Laitch |
Output shaft scare, misdiagnosis and repair.by geoff barnettOutput shaft scare, misdiagnosos and repair. | 2 | 833 | Mon Jun 15, 2020 1:21 pm by moriarti |
[solved]moved pilot bearing bushby tinyspuds | 12 | 1869 | Tue Jun 09, 2020 1:35 pm by SoCalK1P1 |
K75 cranking but not starting.by Kim HunterRecommissioning work get operational. | 13 | 1418 | Mon Jun 08, 2020 11:49 am by Point-Seven-five |
Refurbed driveshafts for saleby tinyspuds | 0 | 779 | Mon Jun 08, 2020 1:56 am by tinyspuds |
Smoking when startingby blueeyedogreSmoking when starting the bike | 20 | 1250 | Fri Jun 05, 2020 8:29 pm by Two Wheels Better |
Water/oil pump questionby dakelvinatorThis was waiting for me this morning! | 34 | 2936 | Thu Jun 04, 2020 5:05 pm by moriarti |
K100 1985 tiny bearings bottom of the clutch case areaby junitiger1Unknown tiny ball bearings | 19 | 1456 | Wed Jun 03, 2020 3:24 pm by Laitch |
Main seal (probably) weeping[ 1, 2 ] by TIV | 65 | 5889 | Fri May 29, 2020 3:54 pm by stanthomas |
Bike lost all power and won't start..[ 1, 2 ] by Tommy2305 | 55 | 2501 | Tue May 19, 2020 5:03 am by Tommy2305 |
Flooding after trickle chargingby audibob | 19 | 1169 | Fri May 15, 2020 5:48 pm by daveyson |
Reaction in fuel?by gorio | 15 | 1194 | Sun May 10, 2020 12:57 pm by gorio |
Fuel injectionby SniperX | 4 | 971 | Mon May 04, 2020 8:07 am by Point-Seven-five |
Fuel Injection - Setting Upby Bonzo | 7 | 1133 | Mon May 04, 2020 5:17 am by 92KK 84WW Olaf |
Low MPG (KPL) for you guys across the pondby zaubertuba | 0 | 653 | Sun May 03, 2020 11:53 am by zaubertuba |
Which clutchby the.postman | 8 | 2679 | Fri May 01, 2020 11:53 am by Laitch |
Tool for measuring the Gear transmission oil levelby mentxo | 12 | 3177 | Fri May 01, 2020 11:26 am by Point-Seven-five |
pump done new problemby dakelvinatorjumpy temp gauge!! | 9 | 832 | Thu Apr 30, 2020 12:20 pm by dakelvinator |
K100 Thermostat hose substitution???by StandardK | 9 | 1072 | Mon Apr 20, 2020 6:00 am by StandardK |
Fuel Cap Leakby zaubertuba | 9 | 1037 | Sun Apr 19, 2020 4:31 pm by MartinW |
Topics [50]
- No new posts
- New posts
- New posts [ Popular ]
- New posts [ Locked ]
