Topics [0]
Changing a headlight bulbby Mike101 | 16 | 5051 | Tue Dec 31, 2013 6:14 pm by Sunnyk75 |
How does the gear position indicator work?by defied | 7 | 2508 | Tue Dec 31, 2013 8:47 am by defied |
electricalby tufty666k100rs pick ups | 0 | 1378 | Tue Dec 31, 2013 1:25 am by tufty666 |
LED bulb for headlightby klamityboy | 14 | 3033 | Thu Dec 26, 2013 9:57 pm by Redwight1968 |
WTF is causing this problem[ 1, 2 ] by klompy the grey brick | 59 | 3733 | Tue Dec 24, 2013 12:49 pm by Rick G |
SMALL WIRE ON LEFT SWITCHby RSMITHHMM WHY? | 12 | 1820 | Mon Dec 23, 2013 5:03 pm by RSMITH |
Smaller Batteryby CrazedbikerLooking for something smaller but equally effective | 32 | 6989 | Sun Dec 22, 2013 5:37 am by duck |
anyone used these?by klompy the grey brick | 14 | 1493 | Fri Dec 20, 2013 12:14 pm by Rabidchiwawa007 |
electricalby tufty666poorly k100rs back to life | 5 | 1469 | Mon Dec 16, 2013 11:53 am by Rick G |
poorly 1985 k100rsby tufty666no spark | 7 | 1441 | Mon Dec 09, 2013 10:48 am by Two Wheels Better |
Heated Grip Mysteryby klamityboy | 4 | 1375 | Thu Dec 05, 2013 5:06 am by colinijohnson |
ABS: a flashing questionby Culminator | 13 | 2003 | Tue Dec 03, 2013 10:21 am by Culminator |
Mounting of headlight, signals, signal horn - and led daylights.by erik m | 10 | 1527 | Mon Dec 02, 2013 10:00 am by Inge K. |
Acewell speedo Airhead cable on an 87 K100?by defied | 7 | 2918 | Fri Nov 29, 2013 10:35 am by Rick G |
2nd hand speedo for the 84 k100rsby mongoX | 4 | 1165 | Fri Nov 29, 2013 4:24 am by ReneZ |
Riding lightsby gunsports | 17 | 1750 | Thu Nov 28, 2013 9:26 am by robmack |
Connection between handlebar loom and rear loomby FL1963Is there a connector block to connect the fron handlebar loom to the rear electrical loom? | 7 | 1359 | Wed Nov 27, 2013 5:29 am by FL1963 |
I had a fireby Mike101 | 4 | 1242 | Tue Nov 26, 2013 12:57 am by charlie99 |
Fuel pump.by geordie boyFuel pump continuous operation. | 3 | 1415 | Sun Nov 24, 2013 9:37 pm by geordie boy |
Dicky indicator switch left hand sideby fender22 | 6 | 1369 | Sun Nov 24, 2013 2:34 pm by Rick G |
Wiring - current carrying capacityby KioorsA question on safety while installing aftermarked heated grips | 2 | 1152 | Sun Nov 24, 2013 1:56 pm by Rick G |
Blinker Genie (or running light conversion!)by snowbeard | 5 | 1834 | Wed Nov 20, 2013 10:47 am by AJ.Valente |
sparks from the caps in the darkby snowbeard | 43 | 2474 | Fri Nov 15, 2013 8:46 pm by dutchie |
fuel pump problemby penfold67please help | 9 | 2139 | Fri Nov 15, 2013 10:25 am by Rick G |
Cable upgradeby TIV | 8 | 1558 | Thu Nov 14, 2013 4:50 am by Arlina |
Fuel and temp instrumentsby Mike101 | 3 | 1195 | Wed Nov 13, 2013 6:33 pm by Mike101 |
Red warning lightby Mike101 | 13 | 1731 | Wed Nov 13, 2013 8:33 am by MT350Explorer |
swapped FI- was ok, now running rough again PROBLEM SOLVED !!!by colinijohnsonHELP PLEASE.... | 21 | 2097 | Tue Nov 12, 2013 4:59 am by charlie99 |
help with removing speedo unitby colinijohnsonPlug connector | 6 | 1420 | Mon Nov 11, 2013 5:00 am by colinijohnson |
green start buttonby alanretired '85 K100floppy green start button | 23 | 2572 | Sat Nov 09, 2013 11:08 am by Rick G |
fuel pump / fuel level connector leakby alanretired '85 K100When I disconnect the connector it is always wet (gas I think) | 4 | 2092 | Wed Nov 06, 2013 10:59 am by ReneZ |
Life without a Throttle Position Switch .....6 months onby jonnyqq | 43 | 7135 | Tue Nov 05, 2013 10:14 am by Comberjohn |
CW Thermoelementby zonenfeile | 1 | 1435 | Thu Oct 31, 2013 6:07 pm by Rick G |
Amp hours on batteries for our bikes?by snowbeard | 1 | 1238 | Wed Oct 30, 2013 11:01 am by Rick G |
malfunction alarm on a 91 k100 ltby IDTWIKAalarm trips | 5 | 1287 | Wed Oct 30, 2013 3:09 am by IDTWIKA |
flashers fixed, but horns and fan... ?by snowbeard | 11 | 1492 | Tue Oct 29, 2013 4:10 pm by Rick G |
Used Speedometer Head Works!by ldrotpkI love my parts bike... | 2 | 1167 | Tue Oct 29, 2013 4:21 am by ldrotpk |
K100rs 16v Ignition switch swap.by sudhirjin | 12 | 2213 | Mon Oct 28, 2013 6:03 am by duck |
Problem with FI relayby KC100Not getting ground from ECU | 4 | 1340 | Sun Oct 27, 2013 9:07 am by 92KK 84WW Olaf |
Dead Battery??by sudhirjin | 13 | 1704 | Sun Oct 27, 2013 3:55 am by Rob Roy Mcgregor |
Bike Sputtersby alanretired '85 K100bike runs but no power | 3 | 1335 | Fri Oct 25, 2013 6:45 am by charlie99 |
1985 K100 low fuel light ?by alanretired '85 K100broken wire | 17 | 3505 | Wed Oct 23, 2013 11:18 am by Rick G |
problem starting[ 1, 2, 3 ] by Ednot starting , possible electrical | 119 | 6178 | Wed Oct 23, 2013 10:27 am by Ed |
Deconstructing my fan and motorby DeRodster | 4 | 1345 | Wed Oct 23, 2013 3:15 am by Inge K. |
Rear brake won't lightby alanretired '85 K100Rear brake won't light, switch ok! | 18 | 2926 | Tue Oct 22, 2013 3:27 am by duck |
Water Temp sensorby Ken F | 3 | 1559 | Mon Oct 21, 2013 4:16 pm by RT |
Tachometer stops earlyby alanretired '85 K100Tach will not read past 6700 rpm | 8 | 1478 | Sun Oct 20, 2013 6:26 pm by K-BIKE |
Signal faultby BooG | 11 | 1707 | Sun Oct 20, 2013 5:10 am by BooG |
I have now officially decided that my odometer problem is "gremlins"by Jhepburn | 5 | 1608 | Wed Oct 16, 2013 11:55 pm by Rick G |
1985 K100by Amohdbike loses power and shuts off while riding down the road | 39 | 3261 | Tue Oct 15, 2013 12:53 am by Rick G |
Topics [50]
- No new posts
- New posts
- New posts [ Popular ]
- New posts [ Locked ]
