Topics [0]
Getting harder to startby ERasbergK100 RS | 19 | 1320 | Tue Nov 21, 2017 6:53 am by audibob |
85 rs has no rear running light..by websterrear running light out | 9 | 1293 | Tue Nov 21, 2017 12:28 am by webster |
K75 fuel pump failureby Beamer | 26 | 3681 | Sun Nov 19, 2017 11:16 am by Inge K. |
K100RT Odometer not workingRby veetsodometer stopped working | 13 | 2986 | Mon Nov 13, 2017 7:14 pm by Andrew2 |
Dash lights all on but no starter motor spin but speedo activates!by Nigel T | 6 | 1220 | Mon Nov 13, 2017 5:00 am by Snod Blatter |
Which tape for binding wiring looms?by OzbeemElectrical wiring tape | 3 | 1794 | Sun Nov 12, 2017 9:44 pm by Dai |
Testing load shed relayby tonybob | 13 | 2803 | Sun Nov 12, 2017 7:24 am by charlie99 |
Random headlight issueby TheJoker | 2 | 1124 | Sat Nov 11, 2017 8:20 am by robmack |
Manual Fan Switch for K100RTby flyinglowNeed switch pn | 2 | 1989 | Sat Nov 04, 2017 6:00 am by Dai |
Indicators/Hazards light Fault - and strange noises from the relay box??by Bonzo | 6 | 1573 | Tue Oct 31, 2017 11:05 am by robmack |
Installing a voltmeterby coopz1985 K100RS | 5 | 1391 | Wed Oct 25, 2017 2:13 am by BobT |
Ignition switch replacement wiring - Which wires do I need?by Snod Blatter | 21 | 6824 | Mon Oct 23, 2017 9:19 am by Snod Blatter |
Help to identify connectors and moreby ERasbergK100RS '88 | 23 | 1611 | Sat Oct 21, 2017 4:55 am by KiwiK100 |
Anyone have a picture of the instrument cluster connector? (PFA)by boostd4 | 9 | 1796 | Wed Oct 18, 2017 7:59 pm by 92KK 84WW Olaf |
Battery keeps dying on meby AndrewPStarts the bike but eventually dies | 15 | 1728 | Mon Oct 09, 2017 7:17 pm by charlie99 |
GEAR INDICATOR - LCDby WINGLESSDisplay faint | 21 | 2984 | Sat Oct 07, 2017 9:02 pm by Laitch |
throttle balance - bike won't go again...by Cablebeacherthrottle balance - bike won't go again... | 12 | 1275 | Fri Oct 06, 2017 3:15 pm by Point-Seven-five |
Immobiliser/Alarmby DBRMN | 5 | 1076 | Thu Oct 05, 2017 7:21 pm by 92KK 84WW Olaf |
Opening the Motronic Boxby Bonzo | 10 | 2234 | Tue Oct 03, 2017 5:31 am by Motorbike Mike |
AGM battery capacityby nino | 13 | 1589 | Sun Oct 01, 2017 2:36 am by Chuckinator |
Headlight assembly removalby nino | 15 | 2089 | Sun Oct 01, 2017 1:47 am by Ace Handler |
Motronic pin number identificationby KiwiK100 | 19 | 1623 | Fri Sep 29, 2017 5:33 pm by KiwiK100 |
Indicator stuck on-anyone else had this issue?by Motorbike Mike | 11 | 1252 | Tue Sep 26, 2017 8:19 pm by Garyk100 |
SPEEDO NEEDLE DROPPED BELOW 0 - HELP NEEDED PLEASE:)by Tarlin | 4 | 3009 | Mon Sep 25, 2017 5:08 am by Tarlin |
Fuel tank Electricalby DaleRT | 5 | 1083 | Sun Sep 24, 2017 11:12 pm by charlie99 |
Odometer and Speedometer Repairby flyinglowRecomendations on places to repair this assembly | 4 | 1248 | Sat Sep 23, 2017 2:50 am by Laitch |
Fuel level lightsby timo27 | 0 | 1075 | Wed Sep 20, 2017 3:55 pm by timo27 |
Fuel pump not primingby audibob | 9 | 2054 | Sun Sep 17, 2017 4:25 pm by uhoh7 |
What is this lock for?by BuckyThere is a lock on the side of the fuse box? | 13 | 2310 | Wed Sep 13, 2017 11:44 am by Bucky |
Please help! Maybe bad CDI or other??by 53cr3t5quirr31I need some expert advice with trouble shooting | 15 | 1177 | Thu Sep 07, 2017 10:56 pm by duck |
Battery helpby floydLet me clean the egg of my face first | 15 | 1448 | Wed Sep 06, 2017 8:55 pm by MartinW |
Rear brake light problemby Daytonadave | 36 | 5104 | Wed Sep 06, 2017 7:12 pm by critter |
Turn signal woesby Woodie | 15 | 2768 | Wed Sep 06, 2017 11:24 am by Woodie |
Speedometer weirdness!by BrickboyK1 speedo displaying strange readings. | 4 | 1209 | Tue Sep 05, 2017 11:49 pm by Rick G |
ABS issue on 91 K100RSby OverkillABS problem | 1 | 993 | Tue Sep 05, 2017 11:57 am by duck |
Cluster removal how to?by SniperX | 9 | 1969 | Thu Aug 31, 2017 10:31 pm by 92KK 84WW Olaf |
Cluster removal led neutral lightby timo27 | 6 | 1325 | Wed Aug 30, 2017 6:09 am by robmack |
86 K100 - bouncy tach needleby duck | 5 | 1547 | Mon Aug 28, 2017 12:34 pm by duck |
Oil pressure lightby timo27 | 7 | 1398 | Sun Aug 27, 2017 12:03 am by Corkboy |
Indicator brings on hazard lightsby FliggyRHS indicator = Hazards | 25 | 3078 | Thu Aug 24, 2017 7:15 am by sidecar paul |
'85 K100RTby ibwillisNeed help | 7 | 1294 | Thu Aug 24, 2017 2:35 am by 92KK 84WW Olaf |
Fuel sending unit ideas?by KJustin | 9 | 1957 | Wed Aug 16, 2017 8:34 pm by charlie99 |
Starting without original speedometerby Laapottijstart working engine turning but not starting | 13 | 2293 | Fri Aug 11, 2017 10:28 am by 92KK 84WW Olaf |
Solid non-flashing ABS light in cluster (K1100 ABS I)by duck | 1 | 1147 | Fri Aug 11, 2017 2:40 am by Point-Seven-five |
A shout to the Irish!by club_c | 3 | 1141 | Tue Aug 08, 2017 8:09 pm by 92KK 84WW Olaf |
Do all K models have self canceling turn singals?by boostd4 | 1 | 1146 | Sun Aug 06, 2017 5:28 am by duck |
Help needed - sudden troubles with starter motor, front light & instruments lightsby ffbikersaEngine won't start, lights go off | 7 | 1358 | Sat Aug 05, 2017 7:46 am by ffbikersa |
gearshift decoding for aftermarket instrumentsby charlie99 | 34 | 10841 | Fri Jul 28, 2017 5:11 pm by maz_dede |
Upgrading the headlightby MD K100RS | 18 | 2847 | Thu Jul 27, 2017 1:59 am by 92KK 84WW Olaf |
fuel pump power diagnosisby kstarfuel delivery electrical issue... | 5 | 1261 | Sat Jul 22, 2017 6:15 am by robmack |
Topics [50]
- No new posts
- New posts
- New posts [ Popular ]
- New posts [ Locked ]
