Topics [0]
Dash unit swapby hoon181 | 6 | 1134 | Thu May 10, 2018 4:00 am by hoon181 |
1996 K1100LT rocker switchesby brickrider2 | 5 | 1175 | Wed May 02, 2018 6:04 am by philbuck |
GPI troubleshooting.by George_Pap | 49 | 3018 | Fri Apr 27, 2018 6:02 am by George_Pap |
Intermittent Speedoby nobbylon | 3 | 1011 | Tue Apr 24, 2018 2:24 am by nobbylon |
coil mounting rubbersby gsxrjeffshort | 2 | 969 | Mon Apr 23, 2018 1:07 pm by gsxrjeff |
K100 replacing the loomby TheJoker | 25 | 2102 | Mon Apr 23, 2018 6:47 am by charlie99 |
ABS sensor removalby philbuck | 3 | 1390 | Thu Apr 19, 2018 2:15 pm by 92KK 84WW Olaf |
1984 K100 headlight connectorby EnJCoop | 9 | 1353 | Tue Apr 17, 2018 5:45 pm by duck |
Proper voltage during runningby George_Pap | 7 | 1272 | Sat Apr 07, 2018 9:41 am by Stumpy |
Ignition Switch Removal and Replace with Maintained Switchby jmccrary | 6 | 1558 | Wed Apr 04, 2018 6:11 pm by jmccrary |
Electrical - i thinkby DaleRT | 8 | 1817 | Mon Apr 02, 2018 9:50 am by Point-Seven-five |
K100RT mini Odysseyby George_PapTrying to get the brick to life | 32 | 1305 | Sat Mar 31, 2018 2:02 pm by Inge K. |
I stuff up !!!by Matthew-BrisbaneNot thinking and hit the starter button | 13 | 1243 | Sun Mar 25, 2018 6:06 pm by Dai |
'85 K100RS won't start - need help with diagnostics pleaseby Matthew1971Voltage drop across the ignition switch | 15 | 2145 | Tue Mar 20, 2018 1:55 am by Crazy Frog |
Can Water Temperature Sensor be Bad??????by billhutchsatNo Start, Poor Enrich Running.... | 3 | 1407 | Sat Mar 17, 2018 11:28 am by Point-Seven-five |
wiring m.uniteby desertfoxI had trouble publishing the picture as reply, so I'm starting a new topic. | 1 | 1213 | Thu Mar 15, 2018 7:09 pm by robmack |
Bad harness connector between Hall Effects and Ignition control Moduleby billhutchsatBike will not start or run. | 2 | 1254 | Tue Mar 13, 2018 1:10 am by charlie99 |
Acewell 2853 Speedometer troubleshootingby tborosakRPM jumping up and down | 1 | 1554 | Sun Mar 11, 2018 12:39 am by robmack |
Speedo Optionby Hale_Storm | 11 | 2292 | Wed Mar 07, 2018 5:02 pm by Hale_Storm |
Adding a AutoMeter Temperature Gauge to K100RTby flyinglowCoolant Draing Plug thread size? | 9 | 1625 | Mon Mar 05, 2018 1:53 pm by KiwiK100 |
1985 K100 RS won't startby FrederikHolmPlugs are flooded, sparks when pulled but engine won't start. | 5 | 2172 | Thu Mar 01, 2018 3:44 am by KiwiK100 |
Left turn signal lights stuck onby timz10000 | 2 | 1046 | Sat Feb 24, 2018 3:11 pm by timz10000 |
hall sensor wiringby mister_anger | 3 | 2501 | Sat Feb 24, 2018 10:38 am by Point-Seven-five |
Coil Alternativesby yamaguzzi | 15 | 2009 | Fri Feb 23, 2018 4:36 am by 92KK 84WW Olaf |
Rebuild one unconnected earth where does it go?by wilboSingle earth wire and no idea what it connects to but heads towards back of bike from photos i took on strip down | 6 | 1177 | Wed Feb 21, 2018 6:47 pm by Dai |
1991 K100RS, another no-startby Rabidchiwawa007 | 26 | 1956 | Tue Feb 20, 2018 12:41 am by Point-Seven-five |
Question on headlightsby StefanMajonezK1100LT 1994 headlight with relay | 30 | 1860 | Mon Feb 19, 2018 10:46 pm by MartinW |
test ignition coil on K100by mister_anger | 9 | 3674 | Sun Feb 18, 2018 12:14 pm by mister_anger |
Permanent earth to injectors causing floodingby Quzzy | 1 | 1207 | Thu Feb 15, 2018 3:38 pm by Suzi Q |
electrical gremlin: start cycle on off pulseby kcdman | 8 | 1399 | Mon Feb 12, 2018 11:57 pm by kcdman |
Spark Plugs and ignition wiresby Crazy Frog | 21 | 11009 | Mon Feb 12, 2018 11:02 pm by blaKey |
Small battery mountingby Gaz | 4 | 1310 | Sat Feb 10, 2018 2:24 am by charlie99 |
Money where my mouth is.by indian036 | 14 | 1838 | Thu Feb 08, 2018 1:59 pm by BobT |
Headlamp switch repairby scottiesharpe | 39 | 11132 | Fri Feb 02, 2018 2:21 pm by charlie99 |
Possible MAF sensor faultby MartinW | 7 | 1304 | Mon Jan 29, 2018 2:20 am by charlie99 |
Fan relay disconnected by previous ownerby timz10000 | 1 | 1060 | Sat Jan 27, 2018 4:22 am by Inge K. |
It's time to check the EFI. '85 K100RSby Moore152 | 5 | 1105 | Fri Jan 26, 2018 9:40 pm by robmack |
Starter bumping / pulsing but not rotating fully.by PNWK100 | 11 | 2744 | Tue Jan 23, 2018 5:19 pm by PNWK100 |
Fuel leakby renrivFuel leaking in large quantities. | 10 | 1378 | Fri Jan 19, 2018 11:41 pm by Matthew-Brisbane |
battery informationby buisomabest batterys | 4 | 1149 | Fri Jan 19, 2018 5:44 pm by buisoma |
Poor/no spark on cylinders 2 & 3by renrivBike suddenly drops 2 cylinders -2 & 3 - | 11 | 1477 | Wed Jan 17, 2018 11:10 pm by renriv |
Karamba speedometer calibration program[ 1, 2, 3 ] by robmack | 137 | 12080 | Fri Jan 12, 2018 3:11 am by Dimitris_K100 |
Washed the bike today and now have strange problemsby Matthew-Brisbane | 7 | 1458 | Tue Jan 09, 2018 5:33 am by 92KK 84WW Olaf |
K75C no electricsby Rockman | 8 | 1329 | Mon Jan 08, 2018 5:03 pm by Andrew2 |
Another 90 K100RS no startby MikeGandyStarting problem | 4 | 1412 | Sat Jan 06, 2018 11:46 am by robmack |
Ngk spark plug threaded terminalby gabriel | 13 | 2272 | Tue Jan 02, 2018 5:25 pm by Dai |
Crimped vs soldered joints.by JGT | 12 | 1354 | Sat Dec 30, 2017 5:56 pm by Dai |
Starter will not turn overby Packo | 15 | 1782 | Fri Dec 22, 2017 2:05 pm by Packo |
K100RT resurrection tryby George_Pap | 13 | 1487 | Thu Dec 21, 2017 8:26 pm by Inge K. |
Question about Karambaby propav8r | 7 | 1403 | Thu Dec 21, 2017 2:48 am by charlie99 |
Topics [50]
- No new posts
- New posts
- New posts [ Popular ]
- New posts [ Locked ]
