Topics [0]
The battery is draining itself when not used?by leoooBattery is low at start | 13 | 1326 | Thu Aug 29, 2019 6:23 pm by Arlina |
Same symptoms returned after 2 weeks!by oldbikemartK100RS 16v 1990 | 7 | 1504 | Mon Aug 26, 2019 1:37 pm by oldbikemart |
Acewell fuel gauge fix?by Neil_artI've manage to get the fuel gauge to kinda work | 9 | 3429 | Mon Aug 26, 2019 12:26 am by davemadsen |
Another K100 about to come back to lifeby Tom G | 21 | 2050 | Sun Aug 25, 2019 9:23 am by GF Wollongong |
One cylinders at idleby Heresy23 | 2 | 872 | Wed Aug 21, 2019 10:24 am by Heresy23 |
Bad voltage regulatorby Heresy23 | 2 | 1007 | Mon Aug 19, 2019 1:22 pm by Heresy23 |
1988 K100 instrument cluster on 1983 K100by jande9 | 6 | 1430 | Mon Aug 12, 2019 1:25 pm by jande9 |
Starting issues. No start, intermittent start, starter not stopping.by Kalle | 22 | 1779 | Sun Aug 11, 2019 2:28 pm by Kalle |
Finally found itby StanBlinker fluid | 25 | 1503 | Fri Aug 09, 2019 8:42 pm by JimK |
starter spinnsby lowboyjimmya couple a years back i had a problem with the starter spining and not engaging with fly wheel , | 16 | 1198 | Thu Aug 08, 2019 10:07 pm by Laitch |
Starting/electrical issue K100by bobwhite_okTurned key, turned over but did not start. Subsequent start fails. turn key now no lights etc. | 3 | 938 | Tue Aug 06, 2019 7:26 pm by bobwhite_ok |
Headlight fuse no2 keeps blowing.by Kalle | 12 | 1096 | Sat Aug 03, 2019 3:46 pm by Kalle |
Plug identificationby stevenh5 pin Plug not plugged in | 1 | 819 | Thu Aug 01, 2019 5:57 am by duck |
Wierd !!by stevenhFuel pump won't turn off | 14 | 1756 | Wed Jul 31, 2019 3:27 am by Poupy |
Electrical or fuel?by BooGCylinder one not working | 10 | 993 | Sun Jul 28, 2019 5:58 pm by Arlina |
Blinkers wont turn offby Jrepassy | 6 | 1254 | Thu Jul 25, 2019 4:43 pm by duck |
New used instruments have a few problems.by SniperX | 18 | 1076 | Mon Jul 22, 2019 6:50 am by Dai |
Indicator issuesby GF Wollongong | 4 | 842 | Sun Jul 21, 2019 5:05 am by GF Wollongong |
Blinker Fuse Blowing with BEP 3.0by Jrepassy | 1 | 842 | Fri Jul 19, 2019 4:05 pm by Laitch |
Karamba?by slparry | 3 | 1052 | Tue Jul 16, 2019 9:43 am by Crazy Frog |
Unexplained wire K1100by Arlina | 10 | 1313 | Mon Jul 15, 2019 2:46 am by volador |
Flashing red warning lightby edmundf | 20 | 2131 | Wed Jul 10, 2019 8:02 am by edmundf |
Sparking battery lugby parkyBattery emits a spark when connecting neutral lead to battery lug | 2 | 871 | Sun Jul 07, 2019 8:53 pm by parky |
Fuel pumpby stevenhNew fuel pump is not working | 31 | 1866 | Tue Jul 02, 2019 6:06 pm by Woodie |
Another BEP 3.0 wiring noob questionby George_Pap | 2 | 1392 | Tue Jun 25, 2019 5:25 am by George_Pap |
Naughty K 100 rs 1984 model,by moriartiengine cuts out | 2 | 869 | Mon Jun 24, 2019 6:31 pm by moriarti |
HAL Sensor group buy ?by Matthew-BrisbaneGroup buy ? | 7 | 906 | Mon Jun 24, 2019 7:27 am by Dai |
buzz start relayby tristan285 | 4 | 1010 | Thu Jun 20, 2019 8:53 pm by Laitch |
Will not startby Thicklotto | 13 | 1146 | Fri Jun 14, 2019 2:47 pm by tinyspuds |
Neutral Light / Fuel Light - Koso TNT-04 + BEP 3by George_Pap | 2 | 2427 | Thu Jun 13, 2019 4:24 am by George_Pap |
Switched enginesby tristan285 | 10 | 867 | Mon Jun 10, 2019 4:38 pm by tristan285 |
Fault with indecatorsby residentalien | 3 | 890 | Tue Jun 04, 2019 1:29 pm by residentalien |
Accessories wire??by Heresy23 | 9 | 992 | Tue Jun 04, 2019 1:28 pm by Heresy23 |
Neutral Light for 1985 k100 and Motogadget proby George_Pap | 7 | 1838 | Tue Jun 04, 2019 7:41 am by GF Wollongong |
Kill switch not killing!!!by yamarider | 3 | 1116 | Thu May 30, 2019 6:08 pm by Dai |
Swapping cluster without removing fairing on k100rt?by SniperX | 5 | 964 | Wed May 29, 2019 8:45 pm by SniperX |
unexpected result from a ‘failed’ HES testby tinyspuds | 2 | 797 | Tue May 28, 2019 2:03 pm by tinyspuds |
Charging K100 batteryby moenv | 9 | 1692 | Tue May 28, 2019 11:33 am by td5 |
Wire colours for the 4-pin fuel tank connector ('83 K100)by Dai | 10 | 3124 | Mon May 27, 2019 3:28 pm by Suzi Q |
Gauge issuesby MartcarlProblem with gauge picking up signals to speedometer | 17 | 3004 | Tue May 21, 2019 2:44 am by Suzi Q |
installing aftermarket controls 3 switch i need help plzby Gr-Racing | 5 | 1721 | Mon May 20, 2019 11:38 am by Gr-Racing |
using the heated grip connectoby tinyspuds | 9 | 971 | Sun May 19, 2019 4:18 pm by duck |
Rev gauge specsby GF Wollongong | 12 | 1253 | Fri May 17, 2019 10:07 pm by Dai |
Battery charging light - absolutely necessary?by Dai | 36 | 6467 | Fri May 17, 2019 2:30 pm by duck |
Removing OEM Flasher Relay brick to wire in alternate handlebar switchesby ScottybulletReplacing Controls with 09 GSXR Switches. | 2 | 1307 | Tue May 14, 2019 11:51 am by Scottybullet |
No electrical power on '85 K100by Moore152 | 8 | 1912 | Sun May 12, 2019 7:07 am by Stumpy |
Loss of speedometer and tachometer.by TheJoker | 24 | 2209 | Sat May 11, 2019 9:25 pm by Crazy Frog |
ABS 1 (2.5 Board 16 v)by Ringfad | 2 | 1164 | Fri May 10, 2019 9:23 pm by Dai |
Does anyone recognize this open plug?by Time To Ride | 8 | 1292 | Wed May 08, 2019 8:38 pm by Time To Ride |
Street-legal low-beam auxiliary lights?by StefanMajonez | 7 | 1139 | Fri May 03, 2019 4:27 pm by Laitch |
Topics [50]
- No new posts
- New posts
- New posts [ Popular ]
- New posts [ Locked ]
