Technical, repair and troubleshooting
Forum | Topics | Posts | Last Posts |
Electrical | 2141 | 26580 | '88 k100 not sta... Today at 2:40 pm Dai |
Frame, fairing and wheels | 1672 | 18343 | 1992 K75 luggage... Sat Apr 06, 2024 2:07 am duck |
Engine and transmission | 2134 | 29401 | You get what you... Mon May 06, 2024 9:19 pm Ballzac |
How to – Article from you telling others how to do a specific job | 212 | 1760 | My first spline ... Sun Apr 28, 2024 5:53 am Dai |
Other K bricks (K75, K1100, K1) General discussion. | 260 | 3126 | A K1200R has bit... Thu Oct 19, 2023 6:19 am caveman |
Special tools and jigs | 75 | 843 | Lifting a K75 wi... Mon Apr 15, 2024 7:39 am grosbeak |
Everything about adding a chair(sidecar) on a K Bike..... | 136 | 1982 | Freighting a Sid... Tue Apr 23, 2024 7:33 pm Saxon7 |
K bikes and trailers | 12 | 162 | Adding a Kamper ... Mon Oct 09, 2023 5:01 am Tranberg |
Topics [0]
Leak from front fork K1100RS 1992by Danish biker | 17 | 2027 | Sun Apr 09, 2017 11:30 am by Danish biker |
Ultrasonic Cleaning Questionby TurboBrick | 3 | 1515 | Sat Apr 08, 2017 12:45 am by Rick G |
Error 1223 Water Temperatureby Old Boy | 14 | 1479 | Fri Mar 24, 2017 5:27 am by Old Boy |
Fuel line sizes and options on rear mudguard ?by TheJokerProbably Repungant question, k100rs 1984 | 2 | 1513 | Wed Mar 15, 2017 6:14 am by Gaz |
Old bike with good vibes.by Peterk100rsK100rs back on the road. | 1 | 1188 | Tue Mar 14, 2017 1:07 pm by Point-Seven-five |
Fork bolts over tightened. Drill or tap and die ?by TheJokerOver tightend the small drain bolts by accident. | 12 | 1384 | Sat Feb 25, 2017 8:38 pm by TheJoker |
Minor starting problem.by AL-58 | 9 | 1344 | Thu Jan 19, 2017 11:18 pm by indian036 |
Can I remove the choke?by nods | 20 | 4684 | Fri Jan 13, 2017 8:00 am by Gauntlett |
Too-Fast Idle, TB linkages & What-Worked-For-Meby KafflutIdle at 1700 rpm when warm was just not okay | 9 | 1583 | Thu Jan 05, 2017 10:09 am by Rick G |
Fast Idle .... Latest: It is finally fixed![ 1, 2 ] by KafflutEven with the idle adjustment screw not touching the stopper K100 idles at nearly 1500 | 64 | 11774 | Thu Dec 29, 2016 9:04 am by Kafflut |
Throttle bodiesby smoll1Changing throttle bodies | 9 | 1789 | Thu Dec 22, 2016 10:12 am by smoll1 |
OOPS. Think I should have done some reading first.by werewasi | 6 | 1504 | Sun Nov 13, 2016 3:18 am by Holister |
85 K100 won't shut offby xASmith88x | 4 | 1285 | Fri Nov 04, 2016 10:44 am by xASmith88x |
K1100lt (92) seat woesby DeRodster | 6 | 1408 | Tue Nov 01, 2016 8:00 am by DeRodster |
Running on 3 cylindersby Bigsaxout of storage K | 2 | 1200 | Sat Oct 29, 2016 12:15 am by Bigsax |
Alternator not workingby mackie95 | 5 | 1201 | Sun Oct 09, 2016 12:44 pm by mackie95 |
Magnet on water/oil pump shaft gear?by Bekman | 3 | 1441 | Tue Oct 04, 2016 8:35 pm by Rick G |
K1100RS fairing on K100Rsby Filmcamera | 2 | 1727 | Sun Oct 02, 2016 1:14 am by duck |
Kit for water pump seals?by Bekman | 4 | 1344 | Tue Sep 27, 2016 7:19 pm by blaKey |
Advise/opinions?by RedRT | 26 | 1744 | Sun Sep 18, 2016 8:58 pm by Gaz |
Is my throttle response normal?by Bikesmith | 16 | 1796 | Mon Sep 12, 2016 1:15 pm by Bikesmith |
Throttle cable issueby TheJokerNot sure what's happening but throttle won't spring back. | 17 | 3324 | Mon Aug 29, 2016 9:23 pm by Two Wheels Better |
K100RT 84 Fork Issuesby GF Wollongong | 9 | 1556 | Wed Aug 24, 2016 4:37 am by GF Wollongong |
Misfiring cylinder 2 and 3.by ChocolateFrog | 44 | 2904 | Fri Aug 12, 2016 6:30 pm by ChocolateFrog |
Rattle from front brakesby Giddyup1985 K100RS | 5 | 2101 | Sat Jul 30, 2016 11:27 pm by charlie99 |
K75 intermittent stallingby PasiVeeK 75 runs well, then suddenly stalls, fires again | 9 | 1671 | Wed Jul 13, 2016 6:31 am by 92KK 84WW Olaf |
Leaking master cycliderby eire1400 | 8 | 1315 | Mon Jul 04, 2016 9:37 am by 92KK 84WW Olaf |
fuel pumpby chrisblake | 6 | 1556 | Sat Jun 25, 2016 2:15 pm by Sunnyk75 |
Karambaby rrrrhow to download | 0 | 1183 | Thu Jun 09, 2016 11:42 am by rrrr |
Fuel leakby ckahleer | 11 | 1910 | Tue Jun 07, 2016 8:12 pm by Rick G |
K75, hex key, Allen key | size needed?by Chocolatehex key, Allen key | 15 | 2668 | Sat Jun 04, 2016 11:25 am by Rick G |
Has anyone found a quieter fuel pumpby ckahleer | 4 | 1507 | Fri Jun 03, 2016 6:10 am by 92KK 84WW Olaf |
I think I broke my throttle assembly trying to put on new barsby colly | 1 | 1297 | Thu Jun 02, 2016 11:05 am by KJustin |
K1100LT 1993 Brake Master Cylinder issuesby GF Wollongong | 14 | 2086 | Thu Jun 02, 2016 3:07 am by GF Wollongong |
Koso Gauges, RPM inputby GauntlettSettings for RPM using -ve side of coils feed | 2 | 1372 | Wed Jun 01, 2016 8:38 am by Gauntlett |
Fuel pressure regulatorby GauntlettWhat does the vaccum pipe do | 4 | 1657 | Tue May 31, 2016 12:01 pm by charlie99 |
Having trouble working out Gear ratio'sby GauntlettIt doesnt add up | 2 | 1252 | Tue May 31, 2016 7:40 am by Gauntlett |
Gas Cap Assemblyby elementalfireFit | 2 | 1389 | Thu May 26, 2016 4:48 am by 92KK 84WW Olaf |
Valve adjust, now no startby tonybobdealer checked valve clearance, then next day bike will not start | 7 | 1472 | Wed May 25, 2016 1:50 am by tonybob |
Coolant warning light and fan come on after 1 minute running from coldby half brick | 17 | 1777 | Sat May 21, 2016 1:05 pm by charlie99 |
Can't start a bike that has been off the road a while - any suggestions?by colly | 18 | 1783 | Wed May 18, 2016 7:08 pm by colly |
Clutch Cable adjustment 86 K75by Sunnyk75Replaced cable but now stiff | 12 | 5057 | Tue May 17, 2016 11:48 pm by Rick G |
Clutch 86 K100rsby Flip2lost clutch? | 6 | 1489 | Thu May 12, 2016 1:17 pm by Flip2 |
gas leak around throttle bodyby bgambrogi | 33 | 3386 | Sun May 08, 2016 6:11 am by K75cster |
100rs fuel pump fuseby Flip2blown fuses, no power fuel tank connection | 14 | 2364 | Sun May 01, 2016 4:13 pm by Flip2 |
A whole new set of problems...by Bikesmith | 28 | 3005 | Sun Apr 17, 2016 8:01 pm by Bikesmith |
Thermostat Questionby Bikesmith | 11 | 2074 | Tue Apr 12, 2016 11:16 am by Point-Seven-five |
bike won't start... time for your smart brainsby bgambrogi | 36 | 3285 | Fri Apr 08, 2016 5:15 pm by Holister |
K100 83 engine shuts down when clutch in on the moveby piseth | 3 | 1306 | Fri Apr 08, 2016 4:32 am by 92KK 84WW Olaf |
Developing trust in an unknown bikeby Bikesmith | 6 | 1465 | Sun Apr 03, 2016 10:00 pm by Holister |
Topics [50]
- No new posts
- New posts
- New posts [ Popular ]
- New posts [ Locked ]
